Awesome. Gonna see if the 1 3/4” high dimension will fit in between the grille slats. Thanks again!
On 4/18/2020 at 3:14 PM, Sierra50BMG said:
I found this, I emailed Westin to see if this corrects all 4 or just the center ones. As soon as I get a response I’ll holler.
Oh, and the mounting brackets mount opposite of the recovery hooks! So you don’t lose those, I though for sure they would use the same spot but Westin nailed it on that one(minus cutting the plastic) lol
Must use 4 Relocation sensors
Where would they all fit though? I each side of the recovery hook, that’s 2. Where are the other 2 mounted?
I asked and that’s the response I got. My thought would be to put them back to back on the grill guard. I’m going to order 2 pairs and try it out. You have to drill a hole for the two anyway, I don’t see why they wouldn’t work back to back but may end up drilling a hole for each sensor and mounting them on either side but one high and one low. I probably won’t have them installed until the plastic is repaired on my truck. The part is on backorder so whenever it comes in is when I’ll get it all done, the sensors right now aren’t that bad, can’t use the front but have to hit the disable switch when putting it into drive otherwise they freak out.
Hmmm.....sounds a bit odd but imagine doable. Please keep us updated.
Thanks a bunch
Thanks a bunch
Just installed amp powered steps.  They work great! Next hopefully my 6 inch lift will ship one of these days and I can put new shoes on her.
  • Like 4
Installed a BakFlip MX4 tonneau cover.... straight forward install and took me about a hour by myself. I had camper shells on my last three trucks but didn’t want to lose the camera on this one so I think this will work great to give me a means to lock things up in the bed. Tailgate auto feature works great also.
Got my new lights put together. Decided to use the plastic blanks that fill the factory fog light location on trucks without fogs. They fit well on these plastic panels and I’m very confident that the 3 bolts can support the lights. Much cheaper than other options and look decent I think. About  a $50 mod, if I don’t have to add anything else.
  • Like 4
Update - got them put in the truck. Too cold to sit out there and wire everything today, but they’re at least in there.
Thanks a bunch
Talked with Westin and I was told you can mount the relocation brackets back to back and have to have all four. The sportsman only needs two. I won’t have mine done for a while so hope this helps.
On 4/17/2020 at 7:40 PM, Julio13 said:
Installed grille lights from stoked designs 82423e849f36d637ac8661deabe4d6f5.jpg
You're not the only one with fancy lights :)
