3 minutes ago, Jav_eee said:
I like the idea but I don’t like losing the auto high beams. I’m gonna try to figure a way to do it and keep the autoHB.
That setup allows for auto high beams... I wouldn’t have done it if it didn’t.
8 hours ago, Dali555 said:
Quarantined means, work on the truck, lol...
Installed:
Auto Stop Eliminator - sooooo worth the money!
Jumper to allow the fog lights on with the headlights - that was really bothering me.
Blackened all the badging - still have to do the front but I ordered black and white gel coated American Flag emblems to cover the red, so waiting on that to arrive. (See pics of other emblems)
Installed grip tape on the awesome off-road side steps. (See pics)
So if I keep my lights set to “auto” will this kit allow the fogs to come on with the auto lowbeams?
Yes.
What? I thought it wouldn’t because they don’t work when the fog lights are on. Do you get a fog light indicator on the dash when they’re on?
I believe so, but to be honest I’d have to check next time I’m driving at night. Never really payed attention to the dash lights because I have heads up display so no need really lol. Before you ask, yes I do know that the lights work as stated... fogs are always on when the headlights are on and stay on when the auto high beams activate.
You should watch the videos on the Boost site that I posted... they have great info on this easy little mod.
Edited by Dali555
Oh this mod is for fog lights on while high beams are on. I had it confused for fog lights on without having to push the button every time you drive it.
No, you’re still confused... this mod is for having the fog lights on every time the lights are on. And they stay on when the high beams go on with auto high beams.
Yeah I still am. How does it achieve that if you’re connecting the high beam trigger wire to the fog light trigger wire? How does that automatically enable fog lights in low beam without pushing the button?
I saw their video and and read the question as to whether “intellibeam” still works but I can’t process it knowing how this jumper works.
If you could verify that when your fog lights are on the “A” high beam is also on at night, I’d appreciate it.
Ahhh crap, just went over the entire thread between us... I posted the wrong link.... the jumper I got was this one... I fixed the previous link
https://boostautoparts.com/products/1999-2020-gm-auto-fogs-mod
Edited by Dali555
Go to the same site as above but click on the all lights mod. under chevy/gmc. This will not effect the auto high beam. There are two different mods. One is for fogs on all the time, the other one is for fogs on any time the fog light switch is activated or when you select high beams. The lows will also come on when you select high beams.
Edited by Fltmech
The auto fog works with auto high beams too
Got it. Just picked up a diode at RadioShack (if you can believe that). I’ll be trying it today.
Got the dash cam installed today. Tapped into the heated steering wheel fuse and ran wire through the weather stripping and above the a pillar trim.
So, I just watched this install video and looking at whats included with the kit...any reason why I can't scrounge up a few pieces from inside my garage and make this myself? Its basically 2 quick splice connectors and 1 wire to connect the wires off the 2 identified pins? Anything I'm missing here?
Edited by Trza
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
