2 hours ago, Delta D said:
Installed Air Design OEM fender flares.
Those look nice! Could you post a close up? I was just thinking about getting those exact ones for my truck, but paint them to match the truck.
Almost 9k on this truck and I’m really enjoying it.   +1 on this forum making it even more interesting.  Did a few things over the last few months, installed the 5100s yesterday - which I would not have known about unless other owners posted here! (Was waiting for trailboss compatible fronts)  steps are coming off next, the dealer is replacing them but I’m going to sell the new ones and install some AMPs.
Looking real nice! How do you like the bilsteins compared to the trailboss monotube ranchos?
I will have done a full LED tail light upgrade on my '20 Elevation. It's scorching hot in Houston... Reaching for a cold beer.
df57c48ff02f12931cdc72842f3660df.jpgc6f2b04f2c14a821484fe66af508b29f.jpg4dbeb3dea595bd48c0e3d069e72b0981.jpge3fd2bb10769c5db87456ef792066f7b.jpg
thanks I really like them, drove all over today, around town and on bad country roads.  The rear shocks really seem to cut down or in many cases eliminate the chatter, especially when accelerating over potholes or broken road.  Speed bumps, much better.   The front feels more stable, more confident in turns.  maybe I'm paying more attention but it tracks better on curvy smooth road as well.
I think it settled down just a tad, the body line just above the door handles always makes this truck appear to have a bit more rake than the measurements show.
1 hour ago, GA_LTZ said:
My 3D matte black tailgate inserts came in today. It’s been way past due for a wash so I did a fresh detail and added my inserts. Loving this debadged look. Looks so clean
https://imgur.com/gallery/QbNMWT8
Looks good where did you get them? Mine are flat, the rounded edges look better might have to redo mine.
On 8/7/2020 at 12:35 PM, nobaddays said:
Have any shots from the side? Good looking wheels!
@nobaddays, thanks! Sorry it took me a bit to get back to you, here are some more angles...
Sharp looking truck !
On 8/15/2020 at 8:07 PM, cotect20 said:
Your setup looks great, have been wanting to upgrade to the Eibach lifting struts and rear shocks, could you provide the part number for 2” TB rear blocks or where you purchased?  Do you know how much rake your truck had prior to installing the Eibach struts?  And how much after?  Thanks for the help.
Before I added the front Eibach struts the rear was about 2.75” higher with the 2” Traill Boss block.  Now with my front Eibach’s the rear is 1.25-1.5” higher.  I believe the Trail Boss block is 84379975, I got them from a local lift shop for $20.
changed the wheels...
Looks good did you add a leveling kit?
yes.. I've had the 1.5" front level on since Iast year.  Hard to tell with the angle of the picture.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,286 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
