MVI already has a wireless charging kit for the T1xx trucks. However, for about 1/3 of the price there's a thread somewhere in this forum that lists everything you need to buy from GM Parts to install that feature.
Well here she is so far:
  • Supreme Suspensions 2-Inch Hub and Wheel Centric Wheel Spacers
  • Rough Country Cat Back exhaust with dual black tips
  • Iconic 4" Round Side Steps
  • Gator Tonneau Cover
  • (4) 6" Anzo HID offroad Lights on Sportbar
  • EGR paint matched fender flares w/ black rivets
  • Black Silverado, LT and Z71 emblems
  • Spray in Bedliner
  • 5% back / 20% front window tint
  • White Mirror Caps
  • Tinted Taillight covers
Front/Rear bumpers are getting painted to color match on 10/20, I'll post pics once they're done and back on my truck.
The only thing left I want to do is:
2" Ready Lift for a total of a 4" lift/level
18" Fuel Vapor Wheels wrapped in 35"  Nitto Ridge Grapplers
  • Spray in Bedliner
  • White Mirror Caps
Imo, the round lights on top of the sport bar look a lot better than the full width led strip GM offers in the accessories catalog. Did you wire in a switch, or are you using a key fob remote switch for them?
I haven't wired them up yet, I tucked all the wiring up in the sportbar for now.  I wanted to get some lights on the sportbar sooner rather than later as I felt like it looked too bare with nothing.
I hate the remote switch you get with the GM Accessories lights. I'm considering getting the auxiliary switches through GM Upfitters and using one of them for an off/on switch. I do wonder if the light switch for the last gen trucks with the sport bar lights can modified and used in the T1xx trucks so there's a wire in switch.
Finally got my new soft roll up gator ETX. Easy install. Thought this would work best with dirt bikes in the bed up against the cab.
Finally picked up the cooper's... Discoverer AT3 XLT.
Not enough mileage obviously for a good review but the first 20 minutes were impressive coming from the OE tires.
285/60/20 with 1.5" LK up front. No issues at all. Super happy with the look and initial feel.
1bce8848e43abe9a374316e7bbb1816f.jpg10996ee96052204550b719fe2ca45c63.jpg362d6a85b5f8e3c7fd90bd40123b0981.jpg
  • Like 7
Just put in the GM Z71 floor liners tonight. They are the nicest floor mats I’ve ever seen and I’ve bought weather tech mats for years. Highly recommended and worth the small premium.
I agree with this 100%. I normally order WeatherTech immediately after I get home from the dealership after buying a new vehicle. I decided to pass on that this time since my truck came with the Z71 floor mats. I don't regret it.
Installed Fox 2.0 coilovers, Rough Country upper control arms, Bilstein 5100 rear shocks and alignment.  FYI the Fox shocks are supposed to be factory height for Trail Boss / AT4 but they gave 1" lift...perfect actually.
How do you like the ride of the Fox coilovers?
I wish I could say I notice a difference, but honestly I don't. I do feel like the rear Bilsteins are a little firm.  Which is strange...I had Bilstein 5100s  on all four corners of my 2018 Silverado and the ride improvement was very noticeable.  It was softer on the small bumps but firm and "planted".  That's what I was hoping for.
Edited by Leevon
Interesting I would have expected that you would feel an improvement. The Ranchos are horrible to me.
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
