1 hour ago, Byrds8 said:
I did not. In a video I had seen it showed removing the top shroud and 4 bolts and popping it out a bit. Unfortunately, it pops out those clips. No video mentions it so it doesnt say how to get them back in. I tried everything I could but the angle was just wrong to get it in correctly.
Interesting the wrong way but quick and effective way is to remove the red inserts with small screwdriver or pry tool. Then shove a large screwdriver in and gently twist behind the red inserts to pop off entire backplate if that makes sense. Never have to remove any shroud or grill etc etc and then boom pop new emblem in and done!
Yeah I found that video later when I was looking up trying to figure out how to fix the bumper cover. Would have been nice to find that one first but...I didnt lol. Sucks I did it myself to save money having it installed to have to take it to fix the cover that isnt clipping back in place. Lesson learned I suppose.
yeah i hear the grill is a pain to take off from the bumper cover as well!
Yeah Im sure. Granted I dont know that I could have wired it up without popping loose the grill.
On 1/9/2021 at 10:32 PM, Z71TrailBoss said:
... Apple MagSafe iPhone charger in center console lid (used 3” hole saw to cut a hole in plastic under rubber mat and then hot glued charger in the hole under the rubber mat, works awesome with iPhone 12 Pro).
about to do the same.
are you using a case? got the magsafe charger, and cant get it to connect through the rubber mat. using spigen magsafe case and 12 pro. thanks
You just have to take off hood release handle and that grate underneath it and can fish it through the core support to the headlight harness. Can be a pain and scratch your hands but has to be easier then removing a bunch of stuff!
Hind sight 20/20 and all lol.
Took truck into dealership to see if they would warranty the chrome exhaust tips before 3 year, 36k bumper to bumper was up. Got it back today with new tips. They look great! Lets hope they hold up better than the first ones did.  These do look like they are coated better than my original 2019's were. Way brighter
AS/S Eliminator installed. No more having to even think about it.
Anyone install the Boost auto jumper for fog lights? Thoughts?
I did, super easy, no issues, been well over a year, or maybe 2!
Good, I may do this myself. At $25 its not a great cost and then I no longer have to hit the button every morning. This keeps it permanently on correct? You cannot hit the button after to turn it off.
New to me 2020 Trail Boss LT Crew in Shadow Gray Metallic.  I had to upgrade from a 2020 Custom Double cab because 1) My son hit a teenage growth spurt and him and his buddies don't fit in the back seat any more and 2) turns out my 4'11" wife can't see over the hood on the rare occasion she needs to drive.  So I upgraded to the Crew and LT (with adjustable drivers seat).  Oh darn.
Previous owner took care of a few mods:  Muffler delete, removed all badges, window tint, factory spray-in bed liner, DECKED Truck Bed drawers
I've added a few:  Pulsar LT (no more DFM or ASS), Boost Auto mod (auto-on fogs with headlights and all-6 lights on when bright)
And I have a few on the way: Westin HDX steps, LEDs for backup lights/cargo light, distressed American flag decal for back window, custom black Trail Boss/flag decal for bed.
And a few I'm considering for the future: BAKflip or WeatherTech tri-fold bed cover, Bull Bar or Chevy Nudge Bar
  • Like 5
Installed Bilstein 5100s in front and back. Set them at the 2.5 mark in front. 2.25” Readylift blocks in back. New BF KO2 tires all around. Just waiting for my alignment appointment.
Installed black AT4 badges and fender vents. Smoked out the front amber corners. Made the windows nice and dark for this upcoming Texas summer.
Ordered the GM upfitter switch kit, should arrive next week so looking forward to installing it. Got a 20” dual row light bar I will be installing in the bumper, have a front valence/ cover from a Duramax AT4 on order which has the opening already there so I don’t have to try and cut into the the stock bumper.
4” lift goes on next week as well along with black 22x10 on 35” Nitto Recon grappler, been waiting almost a month to get this put on so I’m excited.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
