On 1/29/2022 at 9:15 PM, gemarsh said:
Any improvement on turbo whine to go along with less restriction?
Update after more driving. I can hear the turbo better a low speeds and the S&B intake sounds different. The AT4 OEM 20" Goodyear Territory MT's drown out the noise at speed. There also seems to be less turbo lag and slightly better acceleration. I've not driven it enough yet to see if there is any MPG +/-.
Would I do it again, yes. The install was very easy (about 20 minutes total) and the part is very high quality compared to the OEM piece. Not saying the OEM piece isn't quality because it is, but the billet aluminum vs the plastic bulge is nigh and day difference. The part has the same connector to the turbo as the OEM part.
On 2/7/2022 at 9:08 PM, AEmedic said:
Well, today I ordered the Retrax Pro XR.  Once it arrives, I'll post pics.
I love the XR. I have had three on three different truck.  They are beasts.
one note if you have a short bed.  Don’t be afraid of moving it off the bulk head (back of bed) a bit.  I mounted mine and it barely covers the edge of the tail gate.  No leaks but will move back a bit. Maybe 1/4” more. See pics.
enjoy it.  Well worth the price you pay.
Thank you, I can’t wait to get it and set it up!
On 1/23/2022 at 5:06 PM, John F. said:
2022 RST 3.0 Duramax. Only a month old. New Havoc HS2 black hoop steps, 20% front tint. Tinted front markers(no pic yet) 3" superlift A arm lift in the mail. Boost Auto mirror spot mod
What's the inside look like????
9 hours ago, NotoriousGT350 said:
I hear ya! Did the same thing.
Same, $65.95. Makes me wish I had a remote job even more since I fill up about every 4 days.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
