Anyone looking for a set of wheel skins?   They are molded covers for the RST wheels.   I am selling my second set. They are brand new in the box, never used or installed as I have a set already.  I've had them on all winter and they have stayed put and held their shine through the salty roads.  I love them on my truck!!!    Better than plastidip!!!
$75 and I'll go half in on shipping.   PM me
Just got my 3" lift installed. Superlift w/upper control arms. Bilstein shocks in the rear. Couldn't be happier. Rides incredible. Looks much better now. Before and after pics.
Got a good deal on some 2.5 bypasses and threw them onto my truck. Took about 15 minutes a side to get them bolted on and then charged with nitrogen. Already had the bypass hoop welded onto the frame/coilover bucket when the dirt king kit was installed. The extra damping is definitely noticeable and gives a better ride. The coilover was valved pretty soft to let a bypass do most of the work.
Added some fog lights that the wife got me for Xmas. Amazon Specials but fir in the factory location, adjustable, LED and the wiring seems good. I wired them into the fuse box to run with the headlights. I think I have it running correctly now.
Added my custom designed and cut decal to replace the original trail boss depiZap_1646082029450.thumb.jpg.8e320a5205b52d4053687ab6cdc13bad.jpgcal.
  • Like 3
Getting the front of my new High Country covered in Xpel film this mornong
Edited by dieselfan1
I took delivery! 2021 SLE. Just had katzkin installed. I plan on removing the running boards tonight. I have a ProComp front spacer I bought from Dylan199 on this site. I also have a Speed Turtle EZ flash module to install this evening as well
Edited by James Mead
added Dylan199 user name
Installed the illuminated GMC Emblem. Sadly, I broke a couple of clips on the grill hence the zip ties. I put epoxy behind the emblem where those clips were to help hold it in place. I have decided, playing with the grill is not fun at all. I am not 100% sure I got the clips in all the way where the painted section is between the grill and the headlight assy. They dont seem to look odd but still not 100%. Either way, its working and doesnt "appear" to be anything off center etc. Next weekend the AS/S disabler should arrive and Ill put that on.
Apparently I did not get the two clips back in on the bumper cover section between the grill and headlight assy. Anyone know how to get those two clips on each side back in by chance? Dealer can look at it on Wed and said it may cost around $150 for labor. If its something simple and stupid I am missing to do it myself I would greatly appreciate the advise. Thanks.
Putco Stainless Steel letters.
Got them at Radco. Half the price the dealer charges
Did you take grill off to do emblem? Just curious
I did not. In a video I had seen it showed removing the top shroud and 4 bolts and popping it out a bit. Unfortunately, it pops out those clips. No video mentions it so it doesnt say how to get them back in. I tried everything I could but the angle was just wrong to get it in correctly.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
