Saved $25 today and installed a diode to jump pins 10 and 22 so the fog lights come on with the headlamps without pushing the button. Had a few diodes laying around so....free mod! LOL
Recently changed up my stance. Bottom pic is the before. It was lowered 1-1.5” on 22s using Belltech adjustable lowering struts in the front and drop shackles in the rear. Top pic is current with a 6” RC lift w/ Vertex shocks and 35” tires.
Replaced the front bumper fascia with one from an AT4 Duramax (mine is 6.2). Has a roughly 24”x3” opening in it. So I put a 20” lightbar in that spot.
Ran all my wiring for my GM upfitter switch and I’ll cut the knee bolster panel tomorrow to wrap it all up. Ran the wiring for the lightbar today too but since I don’t have hot on my switches yet I haven’t tested yet.
  • Like 3
Upfitter switches installed. Not bad at all. I didn’t replace the whole bolster because I didn’t want to take the dash apart. So I just cut into the existing bolster and snapped the switches in. Easy enough.
Unfortunately while doing the battery panel fuse kit I blew the inline fuse for my sub amp. Not sure how because I had the negative disconnected and only moved the terminal ring once. Oh well.
My driveways is pretty angled, the sidewalk is flat, so the light looks to be shining lower than it actually is. I’ll mess with the angles later this week- after I get the 4” lift put on it’ll already make a big difference there.
Got up in the 50s here so I washed both my new trucks.
I forgot how much work it is.
  • Like 5
Lift went on today. Rides really well. Was hailing when I left the shop so didn’t get a chance to take some better pics.
33 minutes ago, dieselfan1 said:
Nice setup. What lift,tires and wheels?
Rough Country AT4 4” lift with the lifted struts (not a spacer lift).
Nitto Recon Grappler 35x12.5x22
Rough Country s95 wheels 22x10 -25
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
