10 minutes ago, NHAT4 said:
Looks good,  but take it all the way and lose the Z71 badge and go w a vinyl decal... will look even better... My 2 cents
I may do that.  Low on the list of plans, however. Need a louder muffler, leveling kit, 33s, intake, and a spray in liner. For some reason, mine didn't come with one and I forgot to ask.
flowmaster 40 is not bad, but if you want loud... maybe the 10 series...   Def on the spray liner....
What about cherry bombs? I want loud when im on it but no drone
On 6/9/2019 at 1:02 PM, cccjrsbox said:
Ordered a couple of pieces of the sticker stuff folks are using for tailgate lettering inserts. Turns out you can buy custom sizes. I ordered a couple of 10"x1" pieces from bdtrims.com in flat red.  $5/piece and $3 shipping.
Basically unscrew the bolts to remove the top cover, clean the "Silverado"  area off with alcohol pad (supplied), reposition cover to mark the edges with pencil, apply the sticker and button it up. Looks sharp
Tried to do this also because I saw you post and thought it was cool.  The bolts holding the plate on will not come out.  Just spin like they are stripped.  Did your bolts all come out nicely?
I had the cherry bomb extreme on mine initially but I removed it.  It's not that loud on these trucks.  If you want loud, do an electric cutout like I ended up doing.  No drone and sounds like a corvette.  Deep and throaty.
I don't remember having an issue.  I do remember though that I had to hold the washer at the top of the screw in place while turning the screw.   Mine were all pretty loose,  so it was pretty easy.  If I had to do it over, I'd probably use some lock-tite to keep them secure-
A muffler delete worked great for me, flow master turned out not to add much sound.
Led license plate bulbs and reverse lights. Waiting for my delivery for the front turn signals. :D
Did you cover the mesh areas as well, or just delete the muffler?  I'm curious how this sounds, because it'd be a cheap modification instead of doing a cat-back system.
Cleaned the interior. Baseball all weekend. Daughter decided to roll in chalk (she looked like a ghost). This is what it looked like when I got home [emoji15]. A little interior detailer spray cleaned it right up
Warning graphic photos
Lonely at the end of the day
Ryan B.
I just happened to cover the mesh screens today only a slight difference.  The muffler delete works great though:
Thanks for the video!!  This is louder than I expected.  No drone in the cab or anything with this setup?
Nope, the catalytic converter on these were supposedly designed by Cadillac engineers and keeps these trucks quiet.  You can hear it when accelerating but not at cruising.  I'd prefer it a bit louder but not willing to replace the cat.  My previous trucks had a deep rumble + drone with common aftermarket cat-backs, but this 2019 setup is drone-less.
Oh - that vid was from before I covered the screens...  its a touch throaty-er now
Good luck-
I just picked the truck back up.
  • Leather Katzkin interior.
    • I had a hard time finding one with all of the options I wanted, with leather.  We checked within 500 miles and there wasn't one.  This one had everything but the leather.  Not anymore. :D
  • 15% tint on the front windows.
  • 5% tint visor on the top of the windshield.
  • Backflip G2 Tonneau.
I'm not so sure about these chrome steps.  Really debating if Amps are worth the the money, or just changing to all black.  It doesn't make sense they'd put these on an RST, which removes chrome!  Nevertheless, lovin' it so far!
  • Like 8
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
