Front Suspension Questions/Help
I'm a high school student and own a 2008 Chevy Silverado 1500. About 3 weeks ago I noticed my front suspension felt off, when I'd turn it just felt loose. I knew I'd probably need new ball joints but I'm no mechanic so I took it to a dealership. My back tire was low so I had them patch it and asked them to take a look at the front so I could know for sure what was going on. They said that I needed new ball joints and tie rods and priced me at $780. I knew the price they gave me was way overpriced and decided to do the work myself. My truck is already at around 170,000 miles and I plan on selling it before I graduate (about a year) so It's not like I'm gonna keep it for another 100,000 miles so I don't need anything super expensive.
There is a local O'Reilly's in my town and there is also a AutoZone about 20 miles away. I've yet to talk to them.
I've done some looking around online and have had hell of a time finding the right stuff for a price to my fitting. The only questions I had were:
I need upper and lower ball joints, my control arms are okay according to the dealership but if I can find a package that includes them I'd look into it.
Does anyone know any good upper&lower ball joints and tie rods that they could lead me to?
Thank you.
Rockauto.com
Ball joints are available for lower, the uppers are integrated into the control arm.
You'll need a press of some sort to remove and install the lower. If you don't have access to a press, we typically recommend replacing the whole control arm thus replacing the bushings (they eventually wear out so might as well do it now).
