Us graphite colored Silverado/Sierra owners have a unique color that is a chameleon when the sun hits it. I mainly see this as a gray color but then when sun hits it in some ways I see a green and even a blue greenish at times too.
Post away on the pics.....
Weather and sunlight play a large factor in what color it decides to be that day!5d58795613318e6efcbdabe3b543e5e2.jpg8c2495dde06fc1dd6461b4f773d38dca.jpg
This is mine...
Edited by SASK_RT
I wasn’t sure what color to enter when adding it to my toll road EZ Pass account.
16 hours ago, gixxerk8 said:
Loving the pics, also helps give us ideas with what color of accessories work with our unique color.
gixxerk8, are those Westin HDX running boards? IF so, how have they been holding up?
Its Amazing how the paint  colors change with the lighting  , green blue and black20180924_182158.thumb.jpg.5d16de427e6e9519280f7b6e5691e5cf.jpg
Yeah, definitely different depending on the light/angle.. a193af913492a3923343233ccd41c6fc.jpg28942534f789beee9666a66a78acf485.jpg
Sent from my SM-N950F using Tapatalk
That color is great looking love how the sun makes it look different. Kinda reminds me of my iridium metallic on my truck when the sun hits it.
Edited by 15 Z71
When I went to pick up the truck I walked past it because I THOUGHT I bought a green truck but it got cloudy and it was blue, :uhoh:
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
