15 hours ago, JR09country said:
I dont know why but this angle really reminds me of the 99-02 body style. Love it!
Sent from my ONEPLUS A6013 using Tapatalk
I think it's because the lighting hides a lot of the character lines, especially on the hood.  The GMT800s were smoother bodies in general, not so busy with lines everywhere.
-Daver
26 minutes ago, AT4x4 said:
Did you go with the standard red color with the GMC logo?  How close does the color match the red tow hooks?  Sorry, I’m a bit anal...  thanks!
Yes, I went with the standard red color and black GMC logo. I did not compare them side by side, but I cant tell a difference while on the truck.
[emoji39][emoji3526][emoji11][emoji8][emoji28][emoji8][emoji10][emoji3526][emoji28][emoji964][emoji591]
On 2019-05-08 at 5:21 AM, NDfan772 said:
yes they are fuel vapors. Offset is +20
I went conservative on the tires and kept the stock tire size 275/60R 20 General ATX.
Looks great, I have the same set up but with +2 offset, dark tint vapors on bfg ko2’s
Edited by CamerNic
  • Like 6
Just picked this up yesterday. Will post more pics later. Raining like a bitch.
Lifetime Ford truck guy, but traded in my POS 2018 Lariat (behind the AT4) for this.
6.2L with offload perf pkg
Edited by FDHog
  • Like 5
Nice! IMO that’s a great trade upwards. Great looking truck!
The silverado is growing on me but the Sierra front end still reminds me of a Ford.
Huh!
I've owned 6 Ford trucks till now. The GMC front end looks nothing like a Ford.
1 hour ago, FDHog said:
Huh!
I'm with you. Don't think the Sierra looks like a Ford either. The only slight resemblance I'd see is the painted plastic by the headlight like on the 2017 F150.  The thing I can't get used too on the Sierra is the sim card looking fender wells. That'll never grow on me... Wish designers would've went either rouund or rectangular. This new fender well design is just hidious. Otherwise, nice looking truck.
Edited by mafd2
They don't bother me as much as the full square wells. Agree that they look like the designer was confused, but they grew on me.
15 hours ago, FDHog said:
Huh!
I know I know.. it's just the first thought that came to mind.. the front end looked and reminded me of the 2019 F150 :(
You're not alone.  From the 3/4 view those headlights and grill design do remind of the F150.  That bar cutting into the headlights is a pretty significant and obvious design feature.  Continue that bar across the grill and done.  I was not a fan the first time I saw it, and ultimately that front-end is largely why I got a Silverado instead.  Not sure why others refuse to see it.
Edited by Daverado
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
