yeah we just grinded the front of the calliper so the tire wouldnt rub but if you didnt want to do that you could get a thicker wheels spacer
  • Thanks 1
Looks like yellow freight color to me. At least the Silverado.
The Tacoma is more of the Inferno Orange GM color. Has a metallic to it.
What the....9efe5ad47a313563b5bf5a7f3af6ba07.jpgb5ade4a534aa63a1465d49f56e021066.jpg
Sent from my Pixel 2 using Tapatalk
I searched cars.com and there are 2 orange Silverados for sale in the country. This one, and one in SD but that one has no pic so might just be a website error.
The one above the window sticker says "$495 special exterior color...Tangier Orange"
Ugly... yes. But if it’s the only one in the country, seems like it would be quite a collectible.
Maybe if it was a trail boss or ltz, but why a special color like that on a base trim LT?
I suppose my thought is simply, first year model of anything, combined with rare factory paint? I agree that it would be more desirable (from a collectible standpoint) on a trail boss or Ltz, but who is gonna do that?!?! ?
8 hours ago, ShamrockShooter said:
How is the tire sound on the bfgs vs the stock duratacs?
The BFG’s are noticeably quieter than the Duratracs. Not that I hated the sound.
There’s a dealership in Albany NY that has one, happened to see it while driving by. It was hard to miss.
That's the same truck. Depaula
I just saw one on the road in Buffalo New York on Niagara Street look like a state truck
I assume these special colors that wind up on the lots are just fleet orders that government agencies backed out of taking delivery. I’ve seen a few LTs also for sale in “game warden green”.
All I know is I’d be pissed if I was the dealer stuck with that thing. Good luck finding a buyer off the street for that.
You are a brave man. I wasnt sure if there was a reason why that hump is on the front of the caliper.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
