2 hours ago, UGADawgs said:
I'm 500 miles in with a 5.3 LTZ and it drives like a Cadillac to me coming from Hondas and Subarus. Smooth and quiet, even with Z71.
Same here. 700 miles on my 5.3 8sp RST Z71. Upgraded from a 2007 LT Crew, so the ride and drive are an exponential improvement.
I have not experienced any vibration or oddities so far. When I first got it, I did feel like the shift from 1-2 was a little abrupt in the mornings when the truck was cold. But I have since come to realize I was babying the accelerator a little much, which was causing that harsh shifting feeling. I had to adjust my foot from its 12-year habits of driving a 4 speed w/OD! ?
I’ve noticed that the 8 speed really works so smoothly when you put it to work. Not mashing on the gas, but just driving it like normal. It’s a GREAT power train, IMO.
Edited by econometrics
  • Like 5
Same! Love the 5.3/8speed combo! Smooth as silk and more power than I could ever need! I have about 5000 miles on mine. Came from a 2011 Silverado half ton with 5.3/6speed and new truck is better in every way! The DFM is so much better than the AFM was (still wish it didn't have this feature but if it's going to,at least they improved it!)
Edited by Ben Berkenpas
  • Like 5
definitely sounds like you need to be super careful with how you wash it. If it's going through a car wash with brushes, any black car will look bad after a few of those. OnThereel said a 2 bucket wash is the best way... I couldn't agree more. One bucket has soapy water, the other is for rinsing... I rinse my wash mitt after i wash each panel both with the hose and in the bucket, then do the wheels and rockers with a separate mitt and do them last. Start with the glass and work your way down. Black is a pain to wash but looks awesome when it's cleaned and cared for properly.
Thanks for the tip. I guess I’ll be hitting up autozone
I’m glad I wasn’t the only one to notice this. I have a 2019 RST and I noticed this for the first few weeks I got the truck. If I don’t baby the throttle as well it doesn’t have the abrupt shift form 1-2 from a cold start. The first few times it happened I remember thinking I really hope my brand new truck doesn’t have a transmission problem.
Autogeek has everything you'll need.
13 hours ago, cccjrsbox said:
57568824795__D3620117-FB4D-467E-A429-8F61D80949D4.thumb.JPG.3696c5b7dff705fcfedd2c7ddb8dd3bc.JPG
Looking to put on side steps Ricky's
I got real lucky with mine.  They had a scuff mark on the driver side one so they gave them to me for free.
Look up bulletin #16-NA-361 harsh 1-2 shift upon first startup shift under light throttle. GM says it normal on the 8 speed. It has something to do with the initial clutch fill time of the C4 clutch. No fix for it. Gm says it's normal. I have driven more than one 2019 8 speed and they all do it.
Sent from my Pixel 2 using Tapatalk
  • Like 3
Looks like the steel and white are jacked up on blocks and have no tires and wheels lol.  I don't think black wheels are doing these trucks justice. Just an opinion.
Thanks for posting this. Puts my mind at ease that it’s normal and not our trucks having an issue.
Yeah shitty lighting doesn't help with it being sunny and these trucks parked facing south in the morning either.
Have you seen them in person?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
