Turned out great...With -17 did you have to trim a lot?
Do you also mind sharing the brand and model of the wheels?
Oops it’s -18
But as far as trimming the back part of the mud flaps and the corner of the front valence about 1/2in
Wheels are fuel rebels
Tires-Nitto ridge grapplers
Drove this RST Z71 home tonight. 140 miles to go get it, so I got a great first drive home. Love the ride and new features. Upgraded from my 2007 LT2 crew. Really loving this Satin Steel Metallic. All the sales guys were coveting my truck. Lol
  • Like 13
2019 RST with All Star Edition 22” Wheels and Leather Package
Edited by NKHex19
Updated picture links
  • Like 8
Picked up a new 2019 Silverado 1500 RST Z71 in Black!
Traded a 2018 Tacoma, so far I'm really loving this truck.
Edited by RSTPilot86
  • Like 9
17 hours ago, BlackLS said:
Trail Boss LT.
Just picked it up yesterday.
Excellent choice!
22 hours ago, RyanbabZ71 said:
Looks good like the wheels
Ryan B.
Oh snap For Sale, what are you looking at Ryan for a replacement?
I have a 19 high country on order
Ryan B.
On 3/23/2019 at 7:12 PM, Billet Bowtie said:
Those were the exact same 2 pair I was deciding between from Giovanna. I bought a set of Nove FF wheels that I really liked but found out they could not be drilled for a 6 lug before they were shipped even though some websites show them available for 6 lugs. I also bought a set of used ferrada ft3 wheels that were really cool but they got damaged in shipping. I test fit them before I sent them back and they would need at least a 1/4 spacer to make them work. I am running 305/35/24 Nexen Rodian Hp tires. I have only had them mounted for about a day. They seem to ride suprising well. I will probably have a better feel after a week of use.
Do you mind me asking where you bought the wheels, no luck with anyone local carrying that offset in the Giovanna wheels...Thanks
Rogue wheels on Ebay. Julio is who I talked to I think he is the owner 323-204-5259.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
