16 minutes ago, Billet Bowtie said:
I went thru hell and back trying to find a wheel that would not need spacers. These fit like a glove. 20mm offset 24 x 10 no spacers.
hahaha...I am still going through hell, I think it might be time for me to come back....hahahaha. It seems like only Black Rhino and Giovanna lines look good and are a direct fit (in terms of the street look). Dub says their wheels fit but I reached out to a shop who installed some on a Silverado and he said he had to use spacers...The Bogota or the Dramuno 6 is what I am probably going to end up going with.
@trininatx Customwheeloffsets.com has every configuration you can come up with and customer's photos of their setup with specifics like lift, trimming, wheel size and offset, and tires
Sent from my SM-G975U1 using Tapatalk
@destrada127 ....I have checked them out, the problem is some of the wheels the list as compatible are actually not compatible. I was looking at the Strada Osso, called Custom Offset and they said it would fit, I wanted to confirm so I call Strada and they said it won't fit because of the larger caliper. It's been a hell of a ride thus far..ha
[mention=198984]destrada127[/mention] ....I have checked them out, the problem is some of the wheels the list as compatible are actually not compatible. I was looking at the Strada Osso, called Custom Offset and they said it would fit, I wanted to confirm so I call Strada and they said it won't fit because of the larger caliper. It's been a hell of a ride thus far..ha
Oh my bad. I used their website to look for wheels and then ended up buying from someone else who had already put their wheels on an AT4. I love the easy these look and I was thinking about going with their bigger 22x12 but with -44 offset I would have to lift the truck just to fit the same size tire I already have on now. Good luck finding something
Those were the exact same 2 pair I was deciding between from Giovanna. I bought a set of Nove FF wheels that I really liked but found out they could not be drilled for a 6 lug before they were shipped even though some websites show them available for 6 lugs. I also bought a set of used ferrada ft3 wheels that were really cool but they got damaged in shipping. I test fit them before I sent them back and they would need at least a 1/4 spacer to make them work. I am running 305/35/24 Nexen Rodian Hp tires. I have only had them mounted for about a day. They seem to ride suprising well. I will probably have a better feel after a week of use.
Man, that had to be frustrating. I am glad you got that sorted. It would be awesome to get some feedback in a week or so, and post some more pics...hahaha...it looks pretty clean.
Pulled the trigger today on a Shadow Gray LTZ. Going back next weekend for them to install running boards, tint the windows, and swap the front bow tie for black. The way the light hits this color, it changes from gray to green to blue.
LTZ
Convenience Pkg 1&2
Safety Pkg 1
Trailer Camera Pkg
Z71 & Protection Pkg
Sunroof
Basically everything except Safety Pkg 2 and Tech Pkg.
Edited by UGADawgs
  • Like 8
LTZ
Convenience Pkg 1&2
Safety Pkg 1
Trailer Camera Pkg
Sunroof
Your not kidding.  Looks so much different in light. Either way congrats on a beautiful truck. She sure is purty mate
Lots of shopping around for the right deal and though I was going to have to end up ordering but just picked up my Satin Steel Custom Trail Boss. Couldn't be happier.
  • Like 9
So I finally got my wheels done and now I can show off the bumper and wheels0769940a7d23c011893b984c69e61d09.jpg1e13503eb4faae795df96bd770d62809.jpg
Looks awesome! I have been waiting to get rims for my at4 for a little bit. You are right about custom offsets they have nothing. They posted a video a week or 2 for go about fitment problems for the bigger brakes. So I called them and the person helping me over the phone had no clue. He basically told me anything would fit....
I used a local company that will take them back if they don't fit.
I'm planning to pick up some next week I'm going to go 20x10s tis 544bm with -24 offset. I'm going with 285x60x20 or 33.7x11.5. Nitto ridge grappler Trying to go down one size from yours in keeping the tire proportional.
Did this affect your gas mileage a ton? I have heard 1-3mpg?
Sent from my SM-G965U using Tapatalk
Haven't seen a Custom up close or in person; what's in the headlights? LED or HID? Do they have LED DRL'S?
Good ol’ fashion Halogen bulbs.
Wow really...  '16-'18 1500 trucks including the WT had at least HID so wonder why not at least that for the '19 Custom.  Cost?  Is the Custom DRL's LED (like other models) or do they use the halogen headlight bulb like '14-'15 Silverados?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
