I'm new to this forum, my apologies for the intrusion. I just traded in my 2016 Ford F-150 for this.. a 2019 Silverado RST Z71.
That was when it was just a day old.. last week. Since then, I've added in running boards and spray-in bedliner. Probably will remove the "Silverado" in the back and change it to "Cheyenne" like the Mexicans since I'm usually down in Mexico.
Really impressed so far, getting used to it right now but it's all good so far.
  • Like 7
10 minutes ago, MartyF81 said:
@econometrics it is this one: https://www.amazon.com/dp/B079KXLF57/
@black02silverado it is this one: https://www.amazon.com/dp/B077B25H9K/   I like it so far, I haven't had to really access it yet since I installed it on my 2016 and then moved it to my 2019.   The footage was clear and it worked well... but I just kind of went middle of the road.
That’s the one I purchased as well.
3 hours ago, Leevon said:
Updated photo5c8c006a9a477_IMG_8500(1).thumb.jpg.9ea68b5319a55228b4f1c06e627d8abc.jpg
Your truck looks great!  What tire size?  Is it leveled in addition to being a trail boss, or is it stock?
The extra lights in the bed are nice.
  • Like 3
20 minutes ago, asalinasz39 said:
Jumper wire mod at the BCM?
LED bed lighting is included in the Custom Convinience Package.
Edited by 383
2019 GMC Sierra SLT Crew Cab X31 Off Road
GM Accessories 2 inch lift (AT4/Trailboss)
Rough Country Leveling Lift (1311)
  • Like 6
Oh I see! I have that however I want the cargo lights to light up when I press unlock in joint with the bed lights and reverse lights.
Looks great! So a total of 4” of front lift. How many miles on it with the mod? How are the cv angles looking?
Agree, the truck looks awesome! Good decision to run the white letter out, don't see that very often anymore.
I really dont see a concern with CV angles on this set up.  I think the components switched out with the 2 inch GM Accessories lift make it less of an issue.  I put the ProComp 2 inch leveling kit with the top strut plate and lower plate also did rear blocks on my  2015 Sierra and had more concerns with that application than this set up on my 2019
[mention=61945]econometrics[/mention] it is this one: https://www.amazon.com/dp/B079KXLF57/
Cool. Thanks
New black bow tie! And all weather full front Mats that arrived yesterday.
How does the bow tie install?
Ryan B.
Ryan B.
I had a bunch of Black 3m vinyl left so I just used that. Pretty easy with a razor blade since there is a gap between the chrome outer and gold inner bow tie. My last one I did lasted 3 years before I ended up removing it to get rid of the truck.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
