Nice looking RST, I like the color!
The dealer said my custom would be ready to pick up by noon tomorrow, I stopped in after work this evening and it looks to me like it's ready to go now.
I think this is the first Custom on the thread that isn't a Trail Boss. I'll get more pictures tomorrow.
Edited by 383
  • Like 8
Here she is folks... my 2019 after getting Ceramic coating and Tinted..
2019 Cajun Red Trailboss.  I added Exhaust and Cold Air Intake at the dealer and then did Bed Cover, Underseat Storage, Step Bars, Dash Cam, Console Safe, Illuminated Bow Tie and Grill Lights myself.  Options I ordered from the factory included Sunroof, Convenience II, Full Coverage Floor Mats and Sprayed Bedliner.  Was worth the wait!
Picture taken by me :-)
Edited by MartyF81
  • Like 8
Very nice, looks good. I need to do the shorter antenna on mine.
Sent from my ONEPLUS A6013 using Tapatalk
Looks fantastic, wow.
Which shorter antenna did you put on there? I love the size.
What kind of dash cam did you get and how did you hook it up?
Picked it up today. A couple of pictures next to one of our 2018's at work.
  • Like 7
The last 10 trucks you guys have posted really make me want a Silverado one day. Maybe when it's family time. LOVE YOUR GUYS'S TRUCKS!
Gorgeous....
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
