2 minutes ago, mafd2 said:
Wow really...  '16-'18 1500 trucks including the WT had at least HID so wonder why not at least that for the '19 Custom.  Cost?  Is the Custom DRL's LED (like other models) or do they use the halogen headlight bulb like '14-'15 Silverados?
No fancy DRLs on the Custom. I’m sure cost is a big factor, but beyond that, the 14-15 headlights were absolutely atrocious. They basically HAD to use the HIDs in everything to get them by. It would have cost more to redesign a separate new halogen housing for the 16-18 base models.
Looks awesome! I have been waiting to get rims for my at4 for a little bit. You are right about custom offsets they have nothing. They posted a video a week or 2 for go about fitment problems for the bigger brakes. So I called them and the person helping me over the phone had no clue. He basically told me anything would fit....
I used a local company that will take them back if they don't fit.
I'm planning to pick up some next week I'm going to go 20x10s tis 544bm with -24 offset. I'm going with 285x60x20 or 33.7x11.5. Nitto ridge grappler Trying to go down one size from yours in keeping the tire proportional.
Did this affect your gas mileage a ton? I have heard 1-3mpg?
Sent from my SM-G965U using Tapatalk
Thanks. I'm currently averaging 12-15 but I drive mostly city. My best is 22 and that was hwy for a 350 mile road trip. I did have to trim a lot when I put the aftermarket wheels on, but I think I hid it well
Sent from my SM-G975U1 using Tapatalk
2019 Ltz ordered with a 6.2L, installed 275/65/18 Duratracs….after advice from tech at dealer, he suggested that I install the GM 2" leveling kit ( 3 year warranty on it) so went with that.....very happy with it...
  • Like 5
I hear ya. I had a '14 Sierra with terrible lighting (bad projector design). I upgraded to HID's and was an improvement but still not up to par.  I would've needed to upgrade the projectors to Morimoto but didnt. My '16 Sierra SLE had HID and a much improved projector. I Couldn't be happier with the LED headlights in my RST.
Just picked up this 2019 Denali 6.2L with ultimate package in Onyx Black 2 days ago.  Love it!  Had a 2009 Tundra, 2013 4 Runner and 2014 F250 prior.  This truck is next level.
Edited by Tritipnbeer
  • Like 8
Nice, Congrats, Many miles of smiles ahead!
On 10/2/2018 at 2:49 PM, mfbearded said:
Upgrade from 2015 ltz z71.
Could you tell me your wheel and tire size.  How much of a lift is that and does it rub at all.  Thanks in advance...truck looks great!
Edited by jeffreydan32
Spent some time cleaning the truck up yesterday. I had the front windows tinted with future plans to upgrade the exhaust and add subwoofer(s) to the audio. Tires / Rims will be upgraded someday..
  • Like 11
i responded last week some time
22 hours ago, Canoa2 said:
Just installed new wheels on my AT4
WOW...That looks great. Do you mind sharing the following:
Leveled?
Wheel-  Size/offset
Tires - Dimensions
Leveled?
Wheel-  Size/offset
Tires - Dimensions
Stock Suspension
20x10 -18
295/55/20
1 hour ago, Canoa2 said:
Stock Suspension
20x10 -17
295/55/20
Turned out great...With -17 did you have to trim a lot?
Do you also mind sharing the brand and model of the wheels?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
