Finally get it home ! Been long time waiting, ordered in Nov !! Will get a few more pics of her when its all done.
  • Like 6
My LT after adding Fuel Contras and 2.5 inch MotoFab leveling kit!
Looks great, what are the specs on the wheels and what size/model tire?
Sent from my Pixel 3 XL using Tapatalk
What size tire? Rim off set?
Sent from my SM-G965U using Tapatalk
Running 20x9 with +1 offset with 305/55r20 ridge grapplers. It does have the chevy 2" lift on it. No rubbing at all
nice! already some wheels, flares and lift. I have the same truck in black, welcome :) I'm loving it!
Did you install the flares or dealer install? I'm still on the fence about them. I had flares on my Tundra and personally like the look, just not sure what look I want to go for yet haha.
Thanks !  Yes I had dealer do it as it was sitting over there. Those are the rough country ones. I had them on all my trucks, helps with the midwest sh#* on the roads !! They are about 2" over the fender. Works great with that size tire, nothing on mirrors or fenders.
This is a pic from the Detroit Autorama of a different set of fender flares
Traded in the trusty '03 SS (all stock except the stolen wheel thing) for a '19 RST last week
  • Like 8
Any idea of what brand these fender flares are? I looked on lingenfelter website and couldn’t find them. Love them
Edited by Aycock1987
No idea.  I would say call them Monday and see.  I totally agree though, they look sharp
Picked up my truck today after getting the BDS 6" lift installed :)
Headed out for a proper photo shoot but it was a pretty windy day so decided to hold off, snapped a quick phone pic on location though
  • Like 11
I think I found the conversion package from American Luxury Coach
Awesome looking, nice job.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
