On 2/19/2019 at 8:58 PM, jj_marshy said:
Picked up my 2019 Chevy Silverado Trail Boss Custom Crew Cab 4.3 in Shawdow Grey on Saturday. Had the dealer swap my wheel/tire setup from my 2016 Silverado LT to my new 2019. Was very hesitant on how they would look coming from a black truck to a grey truck but I think it turned out good. Lots of accessories and mods to comes. Still think the front end needs just a hair of level to it. So far very happy with truck, it’s my first 4.3 but it still gets it pretty good.
Just finished the leveling kit on mine.        1 1/2 Motofab from eBay for $21. Went on in an hour and sits about perfectly level now
  • Like 3
Do you have the link? Really want to get mine leveled out ASAP! Looks good man! Thanks.
5 hours ago, asalinasz39 said:
Got my AT4 about 2 weeks ago! Very happy with it. So far only got tints free from the dealer all around :)
Looking into a 1 or 1.5” level. Ordered some LEDS for the license plate already.
Putting LED's in license plate will throw a code. Not enough resistance and the ECM recognizes that there's no bulbs. When you get your monthly OnStar report, it will have an attention ! icon stating license plate bulbs are out.  This is also stored in the ECM.  No real biggie but some guys are anal about throwing codes. You'd have to put inline resistors to prevent this.
Edited by mafd2
That’s annoying that even the license plate lights are on CAN bus now. I don’t recall having that issue with my 2016. Does it only show up on the Onstar report, or does the truck alert you in the DIC like it would for a taillight?
On 2/18/2019 at 3:05 PM, steve8 said:
I assume same tint as rear windows. What % is that?
Did you do the coating yourself?
Mind sharing the cost of mods?
Looking good.
-Yes, I tinted the front windows at 20% and tinted the back window an additional 20% to darken the interior a bit more.
-No the coating was done professionally by Nano Surfaces Solutions.
-Tint - $160 for the three windows. Xpel Clear Bra - $745. Paint correction and 7yr coating $1400.
Appreciate the info, and again looking good.
How much does the xpel cover?
On 2/20/2019 at 1:22 AM, FirstAscent said:
Fuel Contra, similar though. Maverick has the deep lip, contra has no lip but concave profile.
And then of course different spoke count
Nice, Thanks... is that a 285/60/20 Ridge Grappler Tire?
Not my truck but according to his pics it looks like that tire and size
Just ordered one. Thanks man!
Just ordered one! Thanks man!
On my 17 I would only see in on the monthly OnStar report. Hope that’s the case with my 19 too.
I dont mind seeing it on the e-mail report as long as the DIC doesn’t show a code its all good.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
