Just finished the leveling kit on mine.        1 1/2 Motofab from eBay for $21. Went on in an hour and sits about perfectly level now
What are your measurements now: floor to center of fender? Front and rear? Whenever you have a chance if you could share that info that would be awesome. Preferably after alignment and suspension settlement lol [emoji4]
Did you install yourself? If yes how did you tackle it? Loosening tire rod end...upper and lower ball joints...and sway bar end links. Or did you follow the “easy way” you tube video where they only lift the truck and loosen the two lower strut bolts...remove and sneak in the spacer then install bolts.
1 hour ago, asalinasz39 said:
What are your measurements now: floor to center of fender? Front and rear? Whenever you have a chance if you could share that info that would be awesome. Preferably after alignment and suspension settlement lol emoji4.png
I drove it about 40 miles this morning. Haven't done alignment yet. You would never even know I did anything from the driver's seat. Rides the same. Handles the same. Steering wheel is straight and it holds it's line with my hand off the wheel. In spite if that I'm still going to get it aligned as I assume it needs it and I don't want to wear out the outside edge of the tires.
The height as of right now is 41.5 to the front wheel well and 40.75 to the rear. According to measurement I'm a bit too high in the front but it looks really nice to me!?
Did it my self. I've done probobly 5 of these over the years. So simple. Hour to hour and a half tops. It helps to have a helper. For me that was my 16 year old daughter.  Trying to get the spacer in and everything lined up to slide the bolt through takes a third hand sometime  Took upper tie rod apart. Loosened sway bar. That's it!
Edited by Ben Berkenpas
do you have a pic of your cv angles after the spacer install?
truck is sitting on a level surface and tires are straight in this picture. The angles really look fine to me!
It looked more on the level  side before the lift. IMO, I would've left it as it was. Now the front end obviously looks higher.
If you stick a level on the top of the box side, it's still too low in the front.
I've always lifted trucks based on level box sides not measurement off ground to wheel openings.  Old square body Chevy's in the 80's, the front wheel well was about 2 or 3 inches higher to the front wheel wells so you had to base level on the box.
I think it turned out great and I wouldn't have wanted to go any less. Just my opinion!
Looks good to me, thanks
3 minutes ago, JR09country said:
Cleaned up the front fender. Debating on removing the trail boss sticker emoji848.pnga96b3c3fd5f05aec7375215566123c3b.jpga61129090799edbac95878d0b1eeb963.jpg
Sent from my ONEPLUS A6013 using Tapatalk
I definitely like removing the fender badges/GM has gotten carried away here/way too big/out of place.
The rear I don't mind as much whether it's trail boss or 4x4.
I took my Trailboss sticker off the first day I had it. One if those things that 10 years from now we will look back and say "remember when Chevy made a "Trailboss!?"
“Trail Boss” is tame compared to some of the packages throughout the 70s and 80s. The “Gentleman Jim” has to be the worst...
  • Haha 1
That is both AWESOME and Embarrassing at the same time!
The height as of right now is 41.5 to the front wheel well and 40.75 to the rear. According to measurement I'm a bit too high in the front but it looks really nice to me![emoji23]
Thanks great info brother! My AT4 has a 2.5” rake from factory...I keep measuring and keep getting 38.25 front and 40.75” rear.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
