15 hours ago, f8l vnm said:
Damn that 157 looks incredible. Beautiful truck man. Love it
Thank you sir!   It is a pleasure to drive everyday.
Pickup up my Silverado RST Double Cab in Satin Steel Friday.  So happy with the truck coming from my analog 2010 Sierra SLT.  Still getting used to the size difference but I'm adapting.  Sorry about the cloudy day picture but the sun didn't come out until yesterday after over 10 days of rain and historic flooding here in NW bama.
Edited by BamaHunter
  • Like 6
That's a good looking truck. I really like the way the double cab looks.
Sent from my ONEPLUS A6013 using Tapatalk
  • Thanks 1
Agree, nice looking truck. Looking forward to seeing that color in person.
I like the idea of removing those fender badges/they're too prominent.
  • Thanks 1
14 minutes ago, steve8 said:
Pictures on the net don't do it justice.  My local dealer traded for it from one 50 miles away.  I was blown away happy when I saw it in person.
On ‎2‎/‎22‎/‎2019 at 9:32 PM, Ben Berkenpas said:
I took my Trailboss sticker off the first day I had it. One if those things that 10 years from now we will look back and say "remember when Chevy made a "Trailboss!?"
Its more of a molded plastic Badge rather than sticker/decal.
The Trail Boss on the bed is a sticker/decal.
19 hours ago, JR09country said:
Finally washed. As you can see I have no tire shine, ordered some from Amazon but the bottle exploded in the box. Should have the liners and tires nice and black tomorrow. ef69f39264c69d104d495d7e7d4a2f20.jpg
Who needs tire shine? After all it is a Trail Boss! Go out and take it off road :thumbs:
Just teasing. Great looking truck JR09
Do yourself a favor and check out the new Adams tire armor stuff lasts unlike any tire product I have ever used
Ryan B.
Thanks and yah, once the newness wears off I'll be more apt to be the boss of all the trails.
Ryan B.
Do you use it on the fender liners? If not, what do you use?
similar to others, just installed a shorter 13" antenna from AntennaX. Didn't go for the super stubby (5-6"), this one should retain any factory quality FM reception.
  • Like 3
Do you have the carpet wheel well liners? My 2010 has plastic and I use the Adams under carriage spray on mine
Ryan B.
Liners are carpet on the K2s and T1s. You kinda gotta be careful what you spray on them. Solvent based tire shines stay “wet” and will do nothing but trap more dust and dirt in the fibers. Those products can also harm the coating on the frame which is exposed beneath the rear liners.
Water based protectants are fine for the carpets, but personally I just leave them alone. They are pretty easy to clean with a brush and hose and they look the same with or without anything extra on them.
Nice truck man
16 minutes ago, f8l vnm said:
Nice truck man
Thanks, I absolutely love it! It'll look even better (to me) in just two more days :)
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
