Vibration after dealer installed bilsteins?
1 hour ago, truckguy82 said:
So I just had my local dealer install bilsteins on the front at the lowest height setting. They also did a tire rotation.
I’m getting a vibration now at 70-80mph. Enough to be very annoying if I drove it somewhere far.
I’ll take it back to the dealer but I want to be informed before I do on possible causes.
They did not do an alignment. They didn’t suggest doing one nor did I think you need to if you keep the bilsteins at stock height. Regardless not sure a lack of alignment would cause a vibration either.
I suppose it could be the tire rotation but feel like that’s unlikely because that doesn’t involve changing the balance.
Thoughts? Possibly forgot to tighten something?
Even though they installed the Bilsteins on the lowest setting you 100% need a front end alignment.
Bilstein states in the instructions that you need to get an alignment no matter what height setting you have.
https://www.dropbox.com/s/qt83y99ws2lg7ll/Bilstein shock instructions E4-WM5-Y458A00.pdf?dl=0
Here are a few items to check after an alignment if the problem is still there.
1. Re torque all your lug nuts
2. Verify that both the driver & passenger retaining clips are in the same position and locked in place.
3. Verify that both the driver & passenger springs are seated correctly on the upper and lower perches.
  • Replies 35
By any chance, what did the dealer charge you for installing the Bilsteins? I have the Ranchos in mine and boy do they sometimes suck.
Rears I did myself, they are really easy and anybody that has ever turned a wrench should do them on their own. It’s literally two bolts.
I had the dealer do my fronts at 1/2 labor for each shock. Costed me $120 in labor.
I had just bilsteins on the rear for like 6 months. I thought it solved most of the ride issue and wasn’t in a rush for the fronts. Man was i wrong, ride is so much better with the fronts on.
Don’t wait to put them on.
Rotate the tires back to the front as before see if vibration goes away. Had the same thing on my 1500 and the second I rotated the fronts to the rear the vibration disappeared on mine. Then I knew for sure one of my rear tires needed balancing.
9 hours ago, truckguy82 said:
Do you know enough about suspension to say that for sure? I thought it was only needed for the lift aspect and not just the shock install aspect.
Yes. Alignment IS needed.
22 hours ago, Sierra Dan said:
I did read it.
Just reiterating it's not related to the new shocks.
Have them check the leaf spring nut torque.
I tightened mine to around 80ft lb and my 70-80 vibration is gone.
Which nut on the leaf spring?  I have a slight shake at 70-80 and am willing to try anything.
Dealer has stated they're willing to chase this issue with me even to the point of replacement, but I refuse to go through that just to get another truck that shakes.  I'd rather take a little time trying whatever it takes to make this truck right.
All 8. The leaf spring U Bolts nuts.
Mine were only somewhere around 50-55ft lb
It was not terrible before like some have reported.
The only way I could tell I had a vibration or shimmy/shake was looking over at the empty passenger seatback and headrest.
Gotta love posters like truckguy82.  He asks for thoughts, then scolds and argues with the responders.  The obvious answer is "take it back to the dealer" but he doesn't want to confront them, because they "hooked him up".
Frakkin' snowflake.
PS  The front suspension on your truck has COILOVER shock units that contain the springs.  Not just shocks!  If you're gonna argue, at least have a basic knowledge of what you're talking about!
Frakkin' snowflake.
I was looking for expert advice, not “you just should do an alignment just because thats what I heard somewhere”
I am well aware of the shock/coilover assembly and have changed shocks, springs, coilover assemblies, tie rods, wheel bearings, sway bars, etc etc etcand I’ve even done a few alignments
What I’m not aware of and what most others don’t seem to be aware of, is the particular procedure for our trucks. Also if you don’t increase the height of the truck and you don’t actually move anything that adjusts camber/caster/toe, why do you need an alignment? Because bilstein adds a generic line in their installation instructions to get an alignment done after installing an adjustable height shock which in 80% of installations people are adjusting the height?
why don’t I want an alignment? Because what many of you don’t understand is if the alignment is actually good, which is was spot on, I sure as hell don’t want somebody changing it.
If you’ve ever done an alignment with a modern hunter machine, you’d know it takes a long ass time to do it correctly and there is no way your typical technician does it like that in your typical 20 minute alignment. Finding someone to do a grade A alignment job is near impossible, and that’s what I had before I took the truck in and am hoping a still have now, a perfect alignment.
Also I said I would take it to the dealer I just want to be informed. I also am taking it to the dealer. I listened to one of the few good posts and came to my senses that it’s probably just a wheel weight that fell off.
So pretty much everything you just said is wrong.
It is OK. The vibration is normal and everyone else here trying to help is triggering your emotions because they are not "experts" as you are looking for.
:shakehead:
It could be as simple as a wheel weight, or a improperly torqued lug nut,  or even loose U bolts which is a common problem, but you will still need an alignment. Your alignment was "spot on" from the factory with the OEM coil overs. You have installed after market coil overs at "factory height" that is not 100% identical to the OEM coil over height. You know how complicated an alignment is, so what if the driver side coil over is 1/64 higher than the OEM coil over? Would your factory alignment still be intact? The GM repair Service manual says to do an alignment check when doing a coil over swap and Bilstein says it as well. Just because your dealer says you do not need it does not make it so. Have him show you the repair Manuel where it says it is not needed.
We are trying to help you.
I show you the instructions from bilstein yet you feel you know more than GM and the manufacture of the product you had installed.
I truly hope the vibration gets fixed no matter what the cause is, and please let us know what the cause and solution was. It could be something someone has not heard of yet!
14 minutes ago, A.J. Curtis said:
:shakehead:
I did not swap the coilovers, this is just a shock install.
Hell yes I would get an alignment if I used aftermarket coilovers.
If you know a way of telling people that you already know more than them about the suspension and I’m looking for very specific help and doesn’t make me sound like a dbag, please let me know. Because I don’t see any nicer way of putting it other than not responding to them which could be considered more inconsiderate.
:banghead: The "shock"  once they swap the oem spring on is a coil over! Jesus dude!!!!!
"Bilstein B8 5100 (Ride Height Adjustable) shock absorbers are designed for trucks and SUV's with a front OE Coilover style suspension."
Did you completely change the front suspension to a different design like Leaf spring or torsion bar?
You do NOT need an alignment because of shock replacement only. Alignments are done via upper control arms and tie rods. NONE of this changes when replacing front shocks on your truck as long as it is the same height. If it truly started after they worked on it then you have a tire balance/road force issue.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 437 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
