19 hours ago, eppieguy said:
I was able to get mine aligned back to factory specs
I'm curious if many TB/AT4s were able to achieve factory alignment specs. No matter where the 2" is placed I don't see why it should matter. I'd prefer to not disassemble the strut.
That is good news! Although yours is a HC; I still lean towards the motofab 1.5" as you and many TB/AT4 owners have done so.  It may now have the rough country extra camber spacer but then again its half inch less therefore less stress on the cv angles.
Same here. The 1.5" is easier to install and should avoid having to change the blocks in the rear as well, as those with AT4/TB achieve a level appearance with the motofab 1.5......2 will probably give a nose high look and stretch the cv angles/ball joints more.
Question for all of you who have installed the 1.5 motofab. I just bought one since motofab now has a TB/AT4 listed on the site. For installation did you need to take all of the steps on their video as far as disconnecting everything to get the space for install. I've seen some videos online where people have done it after getting the truck high enough in the air. Planning to install tonight and get my 35 12.50 18 Ridge Grapplers installed tomorrow, then alignment Saturday morning.
I did all of the steps listed except loosing the top bolts and removing tie rod. Installation was ok....would’ve been easier talking the top bolts loose.
Had it done in about an hour and 15 min without using air tools.
I did all of the steps except loosening the top of the struts on my Trail Boss.
Same with me on my HC, didn't loosen the top bolts.
Any of you have any concerns of premature wear on the ball joints? I purchased a 1.5 inch motofab for my truck but haven't put it on yet because of this concern.
Here’s my alignment sheet from this morning. Hope it helps.
Was going to install mine last night but it's arriving late. Tires just showed up though. Gonna go get them mounted. Hopefully it'll be in the mailbox this afternoon and I'll get it on tonight. So I can get my alignment in the am.
Finished everything up. Had to make my appointment for the alignment next Friday due to shipment delays. 1.5 motofab & 35 12.50 18 Ridge Grapplers with 2" Bora spacers.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
