Well made a discovery today while removing all the build tags . The spare tire is marked “maxxis 750 Tempoary use only”  Bravo?   Anyone else have this as a spare? ☠️
Yep, mine is the same! Full size tire but for temporary use only.
2 hours ago, DougFL said:
The remote close feature should work on all models with the powered tailgate.
Doug,
Power up/down tailgate is standard on High Country and available on LTZ.
Remote-locking and power release tailgate is standard on RST, LT Trail Boss and LTZ, and available on LT. These are not Power Up.
Another small but nice change I noticed. On my 2016 the oil fill was a screw on cap on the valve cover. My 2019 has a filler tube that is high over valve cover and it is level so a funnel sits on it level. Much easier and less messy.  ???
:cool: :thumbs:
What do you guys think of the plastic hood release lever?
Is it beefy or flimsy when operating?
It seems fine to me.  I do not see what the big deal is about a plastic secondary hood release!
4 hours ago, Sierra Dan said:
Doug,
Yep, unfortunately Dan is correct. I just tried it. No power up.
It's plastic but seems sturdy enough.. I don't see what the fuss is.
Two Things learned -
Gap Setting confusion - Came out of a 2015 Suburban with adaptive cruise control (hated it most of the time) and found the same settings on my HC, so figured it was adaptive cruise control given all the other "safety" features in the High Country package. Nope, no real idea what it does, but sure isn't anything to do with adaptive cruise control.
Apple CarPlay and navigation - the HUD and Driver Information Screen will only show navigation when using the onboard navigation but not with when using Apple CarPlay (Assume Google is the same) That's too bad. I tried to "trick" it by using both but engaging one navigation will cancel the other.
The Gap feature, if not used for adaptive cruise is used for the Green Vehicle you see in the DIC when you have a vehicle in front of you. The Gap based on your setting would automatically calculate the distance you should be based on speed. If you are following "too closely" the green vehicle will turn amber in color. I believe you will have 3 settings from close, medium and far. (I do not remember if they use different terms.) This does adjust based on your speed. If you are going 35 mph the gap does not have to be as large as when you are traveling 75 mph even on the same setting.
This is all based on my knowledge from my 2014 Impala LTZ current truck doesn't have the fancy features. I am also going based on the assumption that did not change since. So i still could be wrong.
The Collision Alert (Gap) setting control:
The Collision Alert control is on the
steering wheel. Press to set the
FCA timing to Far, Medium, or Near.
The first button press shows the
current setting on the DIC.
Additional button presses will
change this setting. The chosen
setting will remain until it is changed
and will affect the timing of both the
Collision Alert and the Tailgating
Alert features. The timing of both
alerts will vary based on vehicle
speed. The faster the vehicle speed,
the farther away the alert will occur.
Consider traffic and weather
conditions when selecting the alert
timing. The range of selectable alert
timings may not be appropriate for
all drivers and driving conditions.
Thanks, the confusion is from coming from a vehicle with adaptive cruise that uses the identical controls. I had set the gap and was surprised when I was approaching a car and the vehicle wasn’t slowing.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,479 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
