12 minutes ago, Centrebaseball said:
Interesting because 43R-00072 is what I have in my window right now as a replacement
Sorry I had them reversed, I edited the post. My new window is 43R-000072  Same as yours. Is your new window leak free so far?
so far leak free - just had a raging 8 hr rain yesterday so i'm hopeful that this will be the end of discussion. I have been assured as such. But honestly, I was leak free with the other ones for 6 months so we will see if this one lasts that long too. I can't really tell much difference from the inside to see if they beefed anything up or not.
39 minutes ago, Tomtom87 said:
Could these numbers on the window be lot numbers rather than model numbers? My window that is currently leaking has different numbers than the ones posted in this thread.
That is a Vitro window (different manufacture). Both of my windows were FAYUO. I don't know if anyone on this thread can explain the difference between the two manufacturer companies. I suspect they started with one, changed suppliers, and then changed part numbers again. But who knows??
I just know the most up to date part number they are telling me is FAYUO 43R-000072
Thank you for the clarification. Im interested to know what the possible changes/differences are as well
On 2/6/2020 at 4:45 PM, econometrics said:
I owned my 2/2019 build RST for 8 months before it started leaking. It sat through intense spring rainfall here in North TX, and went through the automatic car wash 5-7 times at least without leaking. Then, one day when it was just a slow, steady rain, I first noticed it.
As I've said many times in this thread, it's not a matter of IF, but when. Just keep your eye out. You don't have to break your neck watching for it, but check from time to time. ??
Yeah I'll keep my eye out for sure, like others have said it's just strange they can't come up with a permanent fix. My last Silverado had the shake so bad, which is what made me trade it in after 4 years. I really hope this one doesn't have another problem that can't seem to be fixed as well.
Van Bortel Chevrolet in Macedon NY.
Kitty runs a good operation. My wife brings here Subaru there and the guy that works next to me whose window hasn't leaked yet got his truck at Van Bortel in Macedon.
Sent from my Pixel 4 using Tapatalk
I am trading in my travel trailer for a new bigger one in two weeks. So I will be hooking up a 5,000 lb trailer and jackknifing it up my steep driveway in reverse probably multiple times to get the right angle. This should put an incredible amount of flex and twist in the frame and cab of my truck. I will then head straight to the carwash to see if my brand new window suddenly starts leaking
Crazy question...has anyone else considered changing the rear window to solid glass?  I have the thought in my head because 1) It seems inevitable that it WILL leak and I don't want the dealership's hands on my headliner, spoiler, trim, etc. and 2) I never wanted the option but convenience group II had other stuff I wanted.
No. That would be dumb. Just buy a can of as seen on TV flex seal and sleep like a baby.469464b210b1ae28d7f0e354d4155037.jpg
  • Haha 2
Costco gives you a free case of flex seal if you buy a Silverado with their autobuy program. Just a heads up.
  • Haha 2
I also said I was going to check out of this thread a while back but it's like a train wreck happening infront of you, you know you should look away but you just can't help but watch....
  • Haha 2
  • Confused 1
Haven’t been following along too close here lately, other than seeing more and more guys joining the leak club unfortunately. Just thought that I would do an update on my truck and window. The truck is still bone dry. I guess it’s been around 4-5 months since they replaced the entire window. It rains a ton where I live and I’ve pressure washed it several times, even had a little snow. No drips, no leaks, so far so good. My window part number is FAYUO 43R-000072.
Edited by WWIII
This is from a Facebook post, just curious if there’s any relation
“Related: today I took my 19 LTZ for the brake, etc recalls. Shootin the $hit with the service writer and he asks how is everything. I say great other than the leak they fixed. He said they are seeing lots “with the antenna leak”. Huh? He said only a few with the window but more with the antenna. News to me.”
So if they know about a problem with the shark fin leaking , all these window replacement might be in vain, couldnt the water run down a channel or along a rail, and drip out down back window or back of headliner
The shark fin was a big source of leaks on the previous generation trucks, but when it did leak, it would be wet exactly where you’d expect it. Front half of the headliner, up to and near the A-pillar.
Hard to dispute on the T1s that the window (and cab spoiler to a lesser extent) is causing the leak. Especially when the cracks in the window frame are plainly visible and the leak goes away when you caulk them.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
