Well, I wish good news. Ha! Had rear window leak repaired with clear silicone beads-3 of them at 8k and now at 8980 miles window is leaking again... so done with this truck. Hopefully my buyout will be approved by EOW. This is not just not because of window leaking, many more issues..
3 hours ago, OnTheReel said:
The shark fin was a big source of leaks on the previous generation trucks, but when it did leak, it would be wet exactly where you’d expect it. Front half of the headliner, up to and near the A-pillar.
Hard to dispute on the T1s that the window (and cab spoiler to a lesser extent) is causing the leak. Especially when the cracks in the window frame are plainly visible and the leak goes away when you caulk them.
Yeah, I don’t buy the shark fin cause of the rear window leak at all. Sounds like Chevy dealer intergalactic logic to me.
Just lost for words that any shop would call that an acceptable fix let alone a gm dealership and this on a brand new truck.  Shame on the technicians and service manager for even handing back the keys like that, really i have to ask because i know we have some gm techs on this website but really how do you even stomach tsb's telling you to do @##@ work like this?
I will preface this with my truck is currently at the dealer for this but was wondering, has anyone tried to remedy this themselves with the sealant? I thought about buying the Kent sealant in the TSB and getting a 90 degree caulk tip and trying to seal it where it's leaking myself. Mine is in two very small spots, no headliner damage. Rather than having the techs destroy the headliner and introduce more leaks through the spoiler.
I took it in just because I would rather have them not try to tell my that by doing it myself they won't cover it under warranty, but was curious regardless.
Yeah i would almost guarantee you that if they found out you had touched it they would void any future claims regarding that issue. I would agree with you to not take that chance.
Day 21 - Still waiting to get mine back, hoping for this week.  All i got was a seal and a new headliner so far.
Just picked up my truck, and from what i can see, looks like the dealer/window installer did a good job. Headliner and trim pieces look good.
The part number of my new window is the FAYUO 43R-000072. The same that other members have received.
So time will tell if this window leaks as well and as always will keep everyone posted
Went in today for them to replace the two pillar panels that got scratched to hell. Looks back to new. Also had them fix the middle seat belt anchor the first tech twisted up into a knot. They also did the second brake BCM reflash recall to fix the bad one applied in December. Truck almost feels whole again. But I'm having PTSD waiting to see if the replacement window will leak or not.
Looks like my adventure has started back up. We have had a lot of rain the past couple of days. I checked on my window which was replaced last week. I could not see any evidence of it leaking. Everything looked good. Just out of curiosity I decided to check under the carpet just inside the rear door on the drivers side. The first place I had discovered wet carpet a couple of months ago.  And guess what? It is wet. So call to the dealership and call to GMC. I'll keep you guys posted. Dammit!
  • Sad 1
Part number of your “new” window?
Wow .... I'm so sorry!!!!    Please keep us updated.  I"m nervous to get mine this week.  I'm going to check the carpet and look for rust like others have stated.
Thanks for the info!
The same number others have been posting on their new windows.43R-000072. I just did further research and found a little water in the track that the window slides in. Nice!
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
