21 minutes ago, Jamie73 said:
The same number others have been posting on their new windows.43R-000072. I just did further research and found a little water in the track that the window slides in. Nice!
Greeeeeat. Keep us posted please
Ok guys. Have gotten my dealership owners cell number and called and received a call back. Explained everything I could remember to him and he said it was totally unacceptable and he was putting his best people on it. So at 5 to 5 this evening I get a text that my headliner is now delivered and they are starting now. The window will be replaced tomorrow morning.
On TFL trucks YouTube video of their trail boss, I commented to check for leaks occasionally in the back. Idk if they read those but I'm sure if they get a leak they will surely let everyone know. Theirs is a 2020 but I think some of those are leaking as well.
Yes they are
I have read through so many posts on this topic, most people arent posting the type of rear window they have.  Are folks with the fixed rear window experiencing same issues?  I could care less about the sliding rear window will really never use it.  Wondering if I should just have it replaced with a fixed glass unit.
Edited by Ethan Fernaays
Don't do that. You'll kill your resell value.
It’s always the sliders. But if yours doesn’t presently leak, I wouldn’t have it pulled out and replaced because you’re just inviting new damaged parts, shoddy work, and maybe a spoiler leak in the end anyway. Not to mention denial of warranty on anything pertaining to future leaks.
I know a lot of people here have had an awful experience with their window leaks/ replacement but it’s really, truly not that bad if it does happen and you have a decent dealer helping you.
Is it a widespread problem? Yes. Is it the end of the world? Not really. Wasn’t for me. I’m just frustrated that GM still hasn’t really addressed it in the trucks rolling off the line now. That’s the worst of it.
  • Thanks 1
mine is leaking.  just got the seal fix and its still leaking.  there is a visible crack in the plastic.  Going to take it back tomorrow.  Hearing that even the replacement sliders they are putting in are failing too thats why im concernes.  I simply just want this to be done,  i dont think a fixed window will kill reseale value, its still a High Country with a 6 2 and almost every option available,  but i could be wrong but when trading in, i doubt that would even be noticed.  The fact is i love this truck other than the leak.
That’s exactly what I would want to do if mine were to develop a leak. Seems like It’s the best solution. Why put another slider in if it’s the same one bound to crack again
Agreed would be just my luck that the replacement would begin leaking at 36001 miles
Haven’t seen this answer so sorry if it’s been asked but is this problem isolated to the 1500 or are people having problems with the new 2500/3500 too?
Oddly, it’s rained like the flood here the past week off and on, and my previously-resealed-leaking-still-window didn’t leak. ??‍♂️???‍♂️
Yet, whenever I have a little morning dew on the top of the truck, I see a drip on the sliding frame corner. ?
4 hours ago, Ethan Fernaays said:
Just got my truck back from the seal "fix" and guess what.... it still leaks..... back to the dealership tomorrow
Sorry. Welcome to the club. It’s like applying for a loan. “Did you get your window resealed? If yes, continue to next step.”
Very few of us have had the sealant application stop the leak.
There was at least one 2020 HD in here. Probably 30 pages ago at this point but I distinctly remember it.
Did u get a replacement window?  has your leak been resolved?
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
