I thought for sure I was going to end up with a leaky window this weekend. Drove 400 miles to my brother's house to pick something up. Drive up was fine. Only had a little bit of fog for a short distance. Just before I got to house I could see storm clouds to the east. They were obviously dropping snow on the mountaintops. Not a big deal to me. Took care of a few things, and right before I'm about to get into my truck and head home it starts to hail, which quickly turns into soft slush balls because it was too warm to be ice.
I then get in the truck to head home and I'm dealing with the slush, which turns into rain, then a strong sand storm that's blowing right to left, then more rain, then more wind, then more rain, and more wind, etc. I was fighting the steering wheel for about 300 miles back home. I thought the stresses on the truck from the weather would expose a weakness. I checked when I got home Saturday night, and again tonight, but still found nothing.
I may have won the lottery on this one.
On 2/17/2021 at 7:00 PM, Mercracing said:
Went through my first car wash yesterday, so far no leaks!
Fascinating. Did you previously have a leak and you're sharing that it is fixed?
  • Haha 1
Sorry for not being clearer. Brand new truck. No leaks yet. This thread has made me fairly nervous about the leak.
Brother, you're not alone.  But be it known, the problem is imho a design issue.  There are 16 holes in the roof under that rear spoiler.  In addition,  the rear window encasement is prone to cracking, something in the design has too much flex, recall those torsional rigidity commercials Chevrolet used to tout.  Torsional rigidity requires an engineer and apparently focus groups are designing vehicles these days and not engineers.   Everyone's truck is 100% susceptible to this leakage.    Driving rain and car wash probably OK.  Sitting outside in the rain for days, or covered in snow, you're gonna leak and it's going to ruin the vehicle.
  • Sad 1
TFL caught some 2022 test models out and about in Colorado this weekend. Maybe GM is finally getting this fixed, as it looks like the spoiler is a different color than the body of the truck here. ??‍♂️
78184069-7B44-4327-9D1B-F1DD0DF4A249.thumb.jpeg.e34e385d0139a9cdfba99b31ed80a75b.jpeg4360EF66-48CF-4063-8A58-A1E163FC25BA.thumb.jpeg.b1327cd37fad800d0c752e92dc7c613c.jpeg
Edited by econometrics
None of the visible rear bumper has exhaust cutouts, so might be entry to mid level trim trucks, which might explain the absence of sliding rear windows on the test mules in that video.
9 minutes ago, Mercracing said:
That’s a solid rear window also. One less leak point.
Disregard the window. I was pointing out the fact that the spoiler is a different color than the body... which just MIGHT lead us to believe it is a new production part for 2022.
Here’s a different truck from the same video WITH the slider. Note the different color spoiler on that truck, too.
I might be over-thinking this, but maybe it’s the hopeful side of me taking over. F6E91528-411B-481B-99B3-398AB0FC37F3.thumb.jpeg.9b067469b7356f9856cc12b84e87f98c.jpeg
Really the spoiler and all the holes associated with it are not the problem.   Yes some people had issues with the yellow retainer gasket and it seemed like it was the same retainer for most people.  Replace the gasket and it’s fine.   Even the one-time use nuts are fine to re-use.  I did and water tested and no leaks.  Although I did ultimately order new ones.   Putting extra sealant around the spoiler holes isn’t necessary imho as long as all the gaskets are fine.  Each hole has a GM gasket of some sort.  It really boils down to the plastic rear window frame.
Imo, the different color means nothing. It's the same style as MY2019-MY2021. Here's a pic of a my 2020 to compare with. Visually it's the same design. 096a53cf328fe2847aa61cd1d5c6b47f.jpg762fcbce91b3d24fb13895f105bf119b.jpg
Dropping mine off tonight.  They are going to water test it, then give me a call.  I plan to go in with the TSBs in hand, and discuss how they plan to address it.
Dropped mine off yesterday
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
