2019 TrailBoss Breaks Down on Ice at Redwings Game
Oh showing off the new truck at the Redwings game? Here enjoy this update so you can't start the truck in the middle of it! Wish/hope that was the issue but didn't sound that easy
Checked by dealer and results was ...did not throw a code and tech could not get truck to repeat it . End result ........operating as designed. lol.  Sound familiar ?  just kidding'
According to the news, the driver accepted an Update over the air which made the truck inoperative for a short period.
That will do it.
Sounds like some CYA for GM. I wouldn't expect them to openly admit that they had an issue that caused it to break down. I would expect some kind of recall soon otherwise to prevent people from doing the "update" while driving on the road ways.
According to the Detroit News, they had shut the truck off to prevent the heat from melting the ice per the protocol at the arena. When they
restarted, the update appeared and was accepted. The vehicle was driven off under its own power.
On 11/29/2018 at 10:15 PM, j-ten-ner said:
Maybe the GMT900 were the last good trucks after all...haha
so long
j-ten-ner
You mean the GMT800's correct?
As long as electronics come into play controlling our vehicles, I feel there is always going to be issues.    The days of old with mechanical systems are gone and so is the reliability, the way of the future unfortunately, and they what driver-less cars?   :lol:
No, I meant the 900 because it's mostly considered as the worst truck build by GM.
Although I hope that I'm not around anymore when driver-less cars take over, it would be fun to watch when a computer goes haywire and they're aimlessly crashing into each other haha.
so long
j-ten-ner
Really.
One hiccup and the sky is falling?
1 minute ago, diyer2 said:
Really.
That's exactly the point.
It is one truck with a hiccup.  No big deal.
Now imagine 1,000 trucks with the a "hiccup", travelling at 60 mph and you have no control.
so long
j-ten-ner
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
