I’ve searched on here, looked at the dealer sticker and emailed to get my build sheet. Looking for a sure way to tell if I have the magneride or not. 2014 1500 Ltz z71
Pretty sure only comes on the Denali.
You do not have Magnetic Ride Control.  2015-2018 GMC Sierra Denali 1500 is the only truck with MRC (standard equipment), minus my one exception below in the next quote response.
Your sticker in the glovebox would have "Z95" on the label if it had it.
 That would be correct with one exception, 2017-2018 Silverado 1500 High Country only with the High Desert package added to it got Z95 Magnetic Ride Control.
Edited by newdude
Is the truck new to you, or did you buy it new? You should have the “factory” Rancho’s that come with the Z71 package.
It’s new to me. Bought it about a month ago and want to do a leveling kit.
If you have a Z71, that's your answer right there.  Can't have mag ride, period, with the Z71 package.  I don't believe you could get it at all on the '14 Chevy either.
Z71 Suspension Package, Off-Road
Z82 Trailering equipment
Z85 Suspension Package, Standard
Z95 Suspension, MagneRide Magnetic Ride Control
When you say dealer sticker, are you referring to the sticker with your option/build codes in the glove box?
No. Talking about the one they stick to the window with a list of features.
Oh, the four square, Monroney sticker. The one in your glove box is your bible for figuring out what you have. You requested a build sheet, so the codes will tell you what each one means. The window sticker just lists standard/optional features in some detail.
3 hours ago, Dwayne Massengill said:
I have a 2009 Sierra Denali 6.2L. Does this have magnetic ride control?
Welcome to the site.
Do you have this code in your glovebox on the RPO sticker: Z95 Suspension, MagneRide Magnetic Ride Control
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
