As the title says, did GM fix the horrible recirculation "feature" for the new T1XX? Not saying the T1XX has a problem wondering if they fixed it from the previous platform. I am about ready to trade my almost new (less than 3,500 miles) 2018 Sierra in on something that will allow us to ride without burning eyes and coughing when following (or stuck behind) a vehicle spewing out stink. Seems no matter what setting I select, it is useless.
Edited by SS502
Are you talikng about ventilation? I thought GM has some of the best in the business.
I cannot comment on the answer to your question, but I have noticed that the smell from other cars (especially people smoking) is much stronger in my 2018 no matter the setting than any previous vehicle I have ever had.
Yes the ventilation system. Doesn't matter where I set the controls the stench/fumes coming from other cars is horrendous. Drove behind (quite a ways back too) stinky diesel and it just fills the cab...every single time. If the outside air stinks you can't keep it out of the cab. I started a bounty fund for @pgamboato come up with a fix...
Edited by SS502
Just now, avalonandl said:
There is a Recirc mode.
Yes, I am aware of it and that's what I am talking about...it flat doesn't work. Even GM has admitted it only cuts out about 60% of the smell from outside because they designed it that way to keep dust out which makes no sense to me but they acknowledge that it lets fumes through.
4 minutes ago, avalonandl said:
It should be 80/20.
OK...I'm not about to argue about the ratio (GM has posted 60/40) of fresh/contaminated air...the bottom line is it lets too much in. There is a whole section over in the K2XX forums about this problem. I am asking if GM fixed the issue for the 2019 because I will probably trade my 2018 in for a vehicle that has a recirculate function that really works.
Edited by SS502
ALL- I am not concerned about the clean/dirty ratio. I am trying to ask 2019 owners if they have an issue with stinky/disgusting Ford exhaust flowing into their cabins when they have the recirculate button pushed. Thank you.
Well, I had the same issues as yours when I had my 2014. My new 2019 is much better, but don't expect completely air sealed.
When I end up behind Marijuana smokers, I turn off the AC and manually push the recirculation button (its light comes ON). In this way, my 2019 seals the vent fairly okay, and much better than my old 2014.
By the way, if I were you I wouldn't get rid of my new truck just because of this issue. Unless you are looking some justifications to get the new one. Then I can give you a list ?
Edited by AMPRG
When I end up behind Marijuana smokers, I turn off the AC and manually push the recirculation bottom (its light comes ON). In this way, my 2019 seals the vent fairly okay, and much better than my old 2014.
First, THANK YOU! I am not wanting to trade in and I know it's never going to completely be free of outside air but not sure I can live with this stench. We have a lot of controlled burns around here and neither of my Honda's let in much, in fact we usually don't smell it until we are past the smoke, then some finds it's way in and that's acceptable. Just this morning I was behind a school bus and not close at all and within a city block it smelled like I was 2 feet off the bumper with my windows down LOL..again, thank you! If I trade I will wait until the second batch of the T1XX is out :thumbs:
HVAC blower box in T1 is different than in K2 by a good bit, but I can't find any specs on recirc from GM.
As far as K2...
This is straight from GM:
Quote
GM Engineering has released updated HVAC calibrations which will close the recirculation door 90% when in recirculation mode. This will allow the HVAC system to draw in approximately 10% outside air, thus slightly pressurizing the cabin, making it more difficult for dust to enter the cabin. This is similar to how the previous generation truck's recirculation mode operated.
Edited by newdude
8 minutes ago, newdude said:
HVAC blower box in T1 is different than in K2, but I can't find any specs on recirc from GM.
As far as K2...
Okay, lets just agree on now 90% it doesn't matter to me if they say 99% the system doesn't work nearly as well as what I've always had, not even close. My 2008 Avalanche worked just fine and both my Honda's work just fine. Anyway, I asked a simple question and based on the replies, I should just live with 60-80-90% blocked off (although I highly doubt those claims) or whatever the real number is. I am not lashing out at you @newdude at least you mentioned a 2019 :thumbs: So I will just shut up and color, it must all be in my head LOL We must be having one of those group hallucinations...
I find it ironic that my 1988 Toyota PU had a sliding damper that went from recirc to fresh and when the recirc door closed no outside air came in......Ohhh the simple things I long for. I really don't understand my 14 Sierra system and do not even really try.
Yotaman
    • Yes they are a good addition to make the truck more visible.   I have the OE ones in the lower front corners. I added some amber fogs to the bumper from Diode Dynamics SS6 model and wired them to my upfitter switches.
    • I had an issue with a new 1985 Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
