For all you AT4 owners, did you pick 18's or 20's and why. There is only one AT4 on the lots where I live and it has the 20in wheels. I haven't been able to see one in person with 18s. I'm planning on buying out of state and was hoping I'd see/drive both before I travel.
I am not an AT4 owner but I would opt for the 18" wheels with DuraTrac tires.
After all this is an "Off Road" package right?
The 20" wheel and less aggressive P type or All Terrain tire just looks funny on such a best, IMHO.
Beauty is in the eye of the beholder.
When I bought my AT4, there were several of both on the lot. The 18s looked better to me so that's what I went with. Not that the 20s were bad. Just not as aggressive on a truck designed like the AT4.
I'm leaning 18's. Would like to see them before in person though. Some of the pics/video angles they look a bit undersized for the vehicle. How are the duratracs for road noise?
Edited by gbaker68
I'm not a fan of the rims at all. But I think the 20s are super ugly. I got the eighteens with the standard tire as I plan on pulling them off the vehicle when the weather breaks in 2 months. Why spend a lot of money on something that I don't like and I can buy a cheaper myself.
I wanted an AT4 fully loaded, so the only option were 20's.
My dealership was great to work with, and they fully credited me the MSRP on the 20" wheels and tires, and got me some Fuel wheels wrapped with 285/65/18 BFG KO2.
I agree on the 20” TB wheels. The stock AT4 20s look out of place with street treads but I’ve seen some with mud terrains swapped and they look good. I’d opt for 18s with duratracs myself though.
I went with 20” wheels and swapped the stock Bridgestone AT for a Nitto Ridge Grappler. To me this is the best combo for a 70/30 mix of on/off road.
What size tire? I want to get some nittos but worried about side lugs and going bigger. My goal would be 35sx 11.5 x20 but I will settle for 34x11.5.
2 hours ago, gbaker68 said:
I'm leaning 18's. Would like to see them before in person though. Some of the pics/video angles they look a bid undersized for the vehicle. How are the duratracs for road noise?
I don't have an AT4 but I have a Trail Boss and I totally think the tires are undersized for the truck.  I swapped mine out the 2nd week I got it.  I actually like the stock 20s better on the AT4 than the 18s but not the tires they come with.
Stock size 33”. Wasn’t interested in going bigger on the stock wheel , just wanted a more aggressive tire then the Bridgestone RHS it came with.
My wifes Tahoe RST has virtually the same wheels as the 20 inch AT4 but in a 22 inch wheel. She gets compliments on them all of the time and I really like them. Ironically I do not like them on the AT4 and would definitely go with the 18s...
I find it super lazy that GMC just raided Chevy's parts bin on a 60k+ truck. They basically called up the wheel manufacturer and told them to make the same wheel with a different center cap in a 20 inch wheel.
39050253f44d1e0971c51d2868026275x.jpg?im
Edited by Chris walker
Road noise isn't too bad. I dont notice it at highway speeds but its there in town around 30-35. Not unbearable though. I've gotten used to it
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
