2 hours ago, Jmonty said:
Any drone? How much louder did it get?
There is a little, I'm not sure if it's any different than the GM Cat back system. It doesnt bother me at all. I kept the flapper valves just in case and I have no intention of welding them back on.
I just put on the GM cat back system this morning...really solid. I can't compare it to what people are getting by just replacing the muffler and cutting out the flappers, but I will say that I'm really impressed. Lots of balls when you're into the throttle, very subdued at highway cruising speeds (I suspect this is largely due to the 10 speed keeping a low RPM when you're not passing somebody).
Great balance. Went on super easy.
I have been contemplating the GM cat back and installing it myself.  When you removed the OEM exhaust, did you have to cut it to get it out?
Ok, so we got it out without cutting it, but this was on a lift with two people manipulating the exhaust back and forth. It takes a little tetris/gymnastics to get it out of there in one piece, but it is 100% doable. On the ground or on jackstands? I'm not sure I would have bothered trying to get it out in one piece.
Of course, once we got it out and realized how long it was, and I had no easy way to transport it (and no real potential to sell it, it's likely going to end up at the recycler), we ended it up cutting it just past the second flapper so I could stick it all in the bed of my truck.
My advice would be to just cut it out with a sawzall, one cut will make pulling the old one out 10x easier. And then the new one goes in exactly as you would expect it to. There aren't any instructions in the box (other than to consult the official accessory service manual, AKA have your dealer do this), but you really don't need any, it pretty much fits together and hangs perfectly. Keep the existing clamp from where the flex pipe connects up toward the front, you'll reuse that one, everything else is in the box.
Edited by SierraAT4
  • Thanks 2
How loud is the performance exhaust in the backseat when you are pulling a trailer and the engine is running between 2600-2800 rpm?
On 3/18/2019 at 8:36 PM, SierraAT4 said:
This video convinced me to buy one:
Thanks for that.   I hadn't seen it before, but it consistent with the difference I saw when adding the exhaust and cold air intake.   My understanding is that it is the Borla exhaust branded as GM.  $2,000 for both installed, but a nice upgrade.
On ‎2019‎-‎03‎-‎21 at 9:44 AM, brothernov said:
Would it make any sense to only add the cold air intake, or only the exhaust?  As I type it it feels like a dumb question, if I increase the air in I'll probably need to increase the trucks ability to expel it, but I know practically nothing about exhaust systems.
Yes. This is what I do with my personal trucks. I put a cold air intake in them and leave the exhaust stock. That way, I only hear the engine noise under load, under normal driving conditions it is silent. This allows me to go on long drives with ZERO exhaust drone. I had a Magnaflow muffler in my 2010 and it was droney, I would end up with a migraine after a 4hr drive. This has been my method ever since to get some noise, hear your motor, but not be droned out so much you hate driving your own truck.
1 hour ago, bshort said:
Who's got the best price on the GM exhaust?
When I bought mine it was shop Chevy parts dot com
Yup. They have a 5% off promo code at the bottom on the site too. Shipping is the only wild card. It was very reasonable for me but if you’re far away it may wind up costing more than ordering at the dealer and having it sent to them.
Just noticed the little silver "performance" badge mixed in with the paperwork that comes with the performance package.  Anyone stick this on their truck?  I'm curious where you put it.  I won't be using mine, it has a Chevy Logo on it, I've got an AT4 :cool:
Test drove an AT4 yesterday with a 6.2 and performance package. Just barely louder than my current 2010 with a 6.2, 3.73 gears, stock exhaust, and K&N CAI. Couldn’t notice sound at all unless I punched it a little. It did seem a little more responsive to the throttle than mine. I went ahead and put my order in!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
