8 hours ago, silspecops said:
what happened with your old setup before you went long travel? did you sell it?
Badass rig man.
Yeah I sold the old set up. In a few months, I'll be deleting 4WD and selling the current front and rear suspension set up; I'll be sure to make a post here when the time comes.
Let me know, looking into possibly getting a setup soon enough so still debating what to run with. If you do sell soon lmk what you're looking to get and location.
  • 1 month later...
Did you convince yourself to go 3.0 in the back instead of 2.5? Just wondering decision process. I know 3.0 obviously should perform better. Also, are you tuning the shocks yourself? Wondering how hard that is or if its best to get a shock tuning pro to set it up. Great build.
  • 5 months later...
On 4/6/2020 at 11:09 PM, AZ_RADO_RNR said:
3rd brake light w/ 2 Baja Design S2's + antenna mount
Is the housing custom made or pre-made somewhere?
Yeah I went 3.0s in the rear. I will be keeping the 2.5/3.0 shock package for my new front set up, longer shock length. Shock tuning, valving etc is not my expertise so I'll have it professionally tuned.
Is that third brake light housing plastic or metal. If it’s plastic you’re hurting your radio signal you need a metal surface for a good ground plane.
Metal, the only non-metal 3rd brake light I know of is from IzzyFab, his is from carbon composites.
Removed the Camburg Mid-travel kit up front (also deleted 4WD) and went with a long travel kit from Dirt King; strapped at 18.5 inches of travel. Just got my +6 front and rear fenders back from paint and 37's will be installed this weekend. I'll post better photos soon, here's a teaser!
Edited by AZ_RADO_RNR
14 hours ago, 175vTrailbossLT said:
@AZ_RADO_RNR  sweet! you plan on rocking this set up with the DK bed cage and shocks for now or you still snowballing this bad boy?
Yeah I'll be running this setup for all of 2021, I need alot of seat time in the truck. As of right now, I'm working on finalizing pricing to do the following:
  • Cab Cage
  • Engine Cage
  • Rear Backhalf
  • Traditional Link's (No short course links for me)
  • Rear Shock Package (3.0s + 3.5s??)
  • Lacing the frame + plating / gussets
  • 70gal Fuel Cell
  • Wilwood Brakes
  • Camburg Rear End (40 Spline Axels, Spool, etc..)
  • Custom plumbing (fuel cell, wiring)
  • PRP Racing Seats (Front & Rear)
  • Custom Interior (Headliner, dash, console, etc..)
  • Hubs
  • Other stuff im missing
All of the big name shops are booked a year out so none of this would get started until 2022 + all these shops require a 1 year downtime so I wouldn't have the truck back until 2023.
  • Cab Cage
  • Engine Cage
  • Rear Backhalf
  • 70gal Fuel Cell
  • Wilwood Brakes
  • Hubs
What’s your process to budget for a build like this? In terms of talking to various shops for example for a cab cage. They are all so busy right now like you said. I think they get a lot of tire kickers so are not that great at quoting work (my experience). Do you find that’s the case or has it not been so bad dealing with the shops and talking to them as you make a decision who to go with? And maybe more specifically what factors do you take when selecting a fabricator? I can’t imagine sending my 4 year old truck off to get town down for a cage haha. Great build though love following this.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
