Picked up my 2019 Silverado today , already had the front differential  replaced and that did not solve the jingle .Field engineer came to the dealership and drove my truck , heard the noise and confirmed it is the drivers side stub shaft coming in contact with the center pin inside the differential, said GM is currently working on a solution for this problem, as of right now there is no fix for it. Said it was safe to drive it this way!  They will contact me when there is a repair is available. Could possibly be 2 or 3 months
I get that it's a first model year but these trucks should not be let out of the factory like this. It really is inexcusable. Hard to enjoy your new truck when you have a major defect right out of the hole.
Just bite the bullet and dump it! Chevy screwed me and the rest of you. Today I was buying some beers and about to leave and the Raptor started raising hell beeping and such. There was a car a good 30 feet coming towards me. The system actually works! If it were the Chevy, they would have to be directly behind you before it told you. It reminds me of the old Nissan’s they called Datsun. They got the message years ago because very few bought the crap
Just curious- did they elaborate as to why it goes away in 4wd?  I guess the torque presses the shaft out a bit...
Unfortunately it happens all the time with all manufacturers. Half of all 3rd gen Tacomas have a howling rear diff that Toyota hasn't done much to address. At this point they basically deny it's an issue. Their front diffs have had vibration issues for years and they haven't done anything to address the issue. Ford has had a garbage 4WD system ever since they went to their IWE front hubs. I know a guy with a 2016 F-150 that's had his 4WD grind up IWE's several times. "Chevy sad" is going to to find out pretty quickly how much Raptors like to eat IWE's.
https://www.youtube.com/watch?v=iOKbCeNztNk
Edited by HondaHawkGT
Yes I noticed as the weather is getting warmer the sound had gotten louder too.
No they didn’t. but im one step away from my lemon law claim after Monday.
iWE’s, most fail at 70-100k miles. I take that any-day over what I just went thru. I feel for ya’all, I loved that truck. I made a mistake, self inflicted pain, of buying a early version and a GM project. They are great looking and that 6.2 with the 10 speed using the 3.42 gears was awesome. But the 16k in options was a joke cause none of the shit worked. I hope you guys get the stuff fixed. Chevy lost a customer who buys every year.
Haha every 70-100k? Maybe back before Ford went all-in on turbocharged engines and cheapened up the vacuum system that IWE's require to function. The IWE's in the 2015+ F-150's have had major problems that continues on today. I know guys that have had the IWE's in their brand new F-150 fail half a dozen times in less than 2 years. Ford still hasn't done anything about it. Didn't really expect them to, though. I mean, they STILL have cam phaser and timing chain problems after 15+ years of designing DOHC engines....
https://www.fordraptorforum.com/threads/cam-phaser-engine-failure-reports.64826/
Look up the facts, not from forums. Just like here. We all bitch about our trucks. I bet most of the new trucks are better than the early builds or at least I hope so.
I am sorry guys, just hate that Chevy is not stepping up. I would have been happy with the Silverado, if they actually fixed things. Old farts like me expect stuff to work like it used to be before we hurt everyone’s feelings.
Please can we not turn this thread into a shitshow?
Keep on topic and let's get to the bottom of this noise and the correct fix.  Looks like we are getting close here.
Thanks.
Thanks, your right! Back on topic. I once had F150 that had nearly all the symptoms. It made a rattling noise and vibrated a small bit about 42 mph. In 4x4 mode all was all well quite and smooth. First they rebuilt the transfer case because they said the driveline was  spinning to fast,  then the revered hubs, finally the found the ring and piñon were shot in the front. In your case, I wondering if the front driveline is spinning in 2 wheel drive. It should be. If not, maybe it’s just sitting there rattling. There are solenoids that activate your synchronizing clutches in the transfer case.
I dunno but if you watched the short video link I posted earlier you can see the play in the drivers side half shaft in and out. I’m 99% certain that’s the noise. For whatever reason in 4wd it must take up that play and make the connection right.
The passenger side shaft is tight in there.
Well the dealer replaced my front differential and the noise is still as loud or louder.  Heading back to the service department again on Monday morning.  Hoping with this new information from this forum they will at least check into it.  Thanks for all that are posting and helping find where the defect is.
Thanks mine is going in today for the diff replacement
    sportfish17
    sportfish17
  • Who's Online   5 Members, 2 Anonymous, 2,009 Guests (See full list)
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
