19 minutes ago, morriseau said:
Mine is a clicking. I don’t know how to post a video on here then I would show you. Shop can’t replicate the sound apparently which is a bummer.
Go back a few posts and see my video. You can hear mine click a few times. Does it sound like mine?
That’s my sound. Must’ve been another video I watched on the comments here.
On 8/20/2019 at 12:13 AM, lworley said:
Well an update sorta.  Thursday GM called me and told me they were going to replace my truck with a new one of equal feature.  They said they'd call me back today with details but have not heard from them.   Tried calling my rep but no answer and no returned call after leaving a couple of messages.  Thursday during the call they wanted to three way call the BBB and drop my complaint immediately. I told them no and now I'm back to being ignored it seems.  Poor customer service and it doesn't seem to bother them.  I spoke with the lady from the BBB today and she said I had eligible Lemon Law case so I guess that's the route I'm gonna have to go.  Can't believe how long this has gone on and how out of touch the people that can actually really help you are.
I had the same issue minus the BBB stuff. I couldn't get a call back about my case, and they would screen my calls. As soon as I called from a different number my case rep would answer. They wouldn't allow me to talk to management either. Their customer service is truly a joke.
1 hour ago, Thejet07 said:
Well after a little over 300 miles the noise is back. I’m soo done
Can you pm me your dealers name and service writer's phone number and your work order number? Mine is scheduled for the jingle fix on Friday and I'll tell them it didn't fix yours, I'd like to give them the name and phone number in case they'd like to call them. I'd rather not have them do it if it doesn't fix it.
your better off letting them try to fix it. that way you have more attempts at repair documented if you decide to lemon law the truck.
The dealer isn't going to care that it didn't fix someone's else's truck. They are doing this fix per what GM is telling them to do.
Exactly what ^^he^^ said let them try it out. It may fix it. It may not. It didn’t for me and probably won’t for you. However, it’s another attempt for your records. I called the dealership and Chevy and of course im waiting for a call back. I don’t remember if I asked or if this has been asked already but does this effect trailbosses as well?
Did you get the old parts or did you see them? I find it hard to believe GM would make that big of mistake. I would tend to believe the mechanics only did part of the work.
I never saw parts. Not really my job to do that. They ordered the parts that were supposed to fix the issues as per tsb. I’m waiting for call back
There are some shady things happen at some dealerships. Some caused by lazy techs. I feel for ya, but when do you call BS and enough is enough. Dumping it like I did is extremely costly. Wishing you luck!
Taking my truck in on Friday so service can go with me for drive so they can hear the.noise. What I'm reading here isn't encouraging. The jingle noise can really get on your nerves.
Does the front axle still have the movement/slop where it enters the differential?
The dealership called me today after they installed the so called FIX and it didn't work. The jingle is still present. He said he was going to call the engineer, I suggested they put a front axle made by GM, they seem to not have a problem.  My have to end up hiring a lemon lawyer
Can someone answer me this.
Aside from the noise, will this have long term effect if left unfixed or is it just an annoyance?
I have a clicking on mine with the occasional jingle, but it's almost always a click.
Maybe because I have a Trail Boss.
I think I rather deal with the click than have those morons work on it and risk messing something up.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,061 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
