I am taking my Trail Boss in tomorrow for this.
Pray for me. lol
I have zero faith in the morons at this dealership.
Only 2,800 miles and it'll already be 3 visits to the dealership.
Taking it in for a stuck tailgate also. Second time for the same thing.
Edited by Sin City Trail Boss
On 8/23/2019 at 4:30 PM, RAYS B4U said:
I just picked up my High Country from having bulletin PIP5653B Jingle Jingle "fix" completed. Now it's a wait and see if it returns.
BAD NEWS!
Today was my first longer drive since the "fix",  unfortunately the "Jingle jingle" was back in less than 50 miles. Will be calling my service writer tomorrow.
9 minutes ago, RAYS B4U said:
BAD NEWS!
Jesus!!!
Does not make me feel good about having mine torn apart.
Guys I just bought a brand new Silverado 1500 Z71 yesterday lol. I’m having the same issue. Hearing a scraping jingle noise. It’s not loud but if going slower with window down I can hear it. Should I worry?  I mean literally just bought it with 6 miles on the odometer. From what I’m hearing the “fix” sometimes doesn’t work and some guys have brought it in 4-6 times and still having issues. Wondering if I should just deal with it and not waste time. Please help.
Where the heck are you reading that people took it in 4-6 times?
Had read somebody on here over 4 times and looking into lemon law. Just looking for insight on this since mine is so new (build date 06/19). Thanks.
This is not an issue GM can sweep under the carpet and hope people quit complaining. I'm old, hearing not so good, and I can hear it above my stereo. Eventually they'll come up with a "fix" that will actually fix it! Take yours in and give them the bulletin number and let them research it, the more complaints, the faster the "correct fix" will come.
Mine is going on today after work.
Don't have much faith it'll fix the problem, but we'll see. I think if enough people keep taking it in, GM will come up with a better fix.
While annoying, at least it's not something that'll leave you stranded so enjoy the truck for now and take it in when you can
Thanks guys. Hope the best for y’all!  So the consensus I’m hearing is: The supposed “fix” isn't fixing all trucks and really it’s a crapshoot at this point. I hate to take the truck in and just to have a band aid situation with it and waste time. I mean if I ultimately have to just deal with it I can. Absolutely love the truck and drives smooth as butter. Just hope it’s not something that gets worse.
The more complaints....the quicker the "correct" fix will come.
I definitely agree. I went ahead and emailed my dealership’s service manager and detailed all the stuff going on and I’ll report back if they (hopefully) respond.
400 miles on my truck and the same issue is going on .taking it in to the dealer Tuesday. Already called the service manager and told him about the TSB. I would not be so dissapointed if the fix for this was actually fixing the problem.
Pray for me. lol
TB's shouldn't have this issue, as I understand our trucks have totally different parts than those with the "jingle jingle"?
Edited by lebag335
type O
Mine only jingles once in a blue moon, especially when hitting a bump I may hear it but I think it's definitely related to this.
I get a pretty loud click and if I put it in 4wd it goes away. Check out my video a few pages back.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
