Thanks lov2fish, what did it take for them to finally replace the diff?
Dealer replaced stub shaft and parts listed in bulletin 5653. When that didn't work, dealer contacted Chevy and they said something about probably no clearance between new stub shaft and cross pin when hot and to replace the front differential. I looked at paperwork on repair last night and it listed the differential and also listed a front axle.
Sent from my SM-G973U using Tapatalk
Thanks, I have read on others customer work orders about the stub shaft possibly rubbing on the cross pin. I'll mention that to my service advisor and see if they'll replace mine too.
58 pages and they still haven’t figured this problem out yet... I’m hoping to get a 2020 Trail Boss in the near future but maybe I’ll just hang onto my 2018 Colorado ZR2 until the 2021 or 2022 Silverados are out... whenever they have it figured out.
Well the sound is back, and it’s 10 louder!! Going back to the dealership next Tuesday
Just don’t buy it if it has the su4 differential from aam
What’s the easiest way to check for those specs while I’m out surfing the Chevy lots, or do I have to use the VIN to find that online?
When you find a truck you like just ask the dealer to pull the Build sheet up. Takes 5 minutes and don't cost anybody anything. Sheet will have a bunch of alphanumeric codes listed. You want Frt axle code SU5 which is the GM sourced axle.
Thanks, I’ll do that.
Tuesday I go in to the dealership for the PIP. Not expecting much other than wasted time. Will have pictures
Hot day/long trip and it's back. Little over 6000 miles since diff. Change.
Test drive a Ford F150 yesterday. Even though nice, still like my Chevy better. May look at a GMC with a su5 axle and be done with it.
I went through this all last year Its the Dog chasing its tail it ALWAYS comes back. Contact the BBB and file a lemon law buyback case its your only ticket to relief. If they repurchased mine for the same issue what makes yours different? They know they are defective.
So to be clear, there has been zero cases of anybody with the SU5 experiencing this problem?
Not that I've heard. Neither of my two trucks, both SU5 frt axles, have made any noise or music.
Thanks
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
