Love how this truck pulls my little trailer. Much better than my 08 Dakota. No problems up those steep canyon roads.
Very nice set up, my neighbor to the north.
Gray clouds look very familiar?
Thanks. It was raining so hard that day. Helped in washing the winter grime off the trailer though.
Brought our 24’ Travel Trailer home from my dad’s farm.  New truck tows like a champ.  Has the max trailering option.
Levelling kit on truck causes a bit of squat though even with a WD hitch.
May need air bags to compensate for level kit.
Do you have any adjustment left in your WDH? Maybe one less chain link on your bars would get you level?
No my torsion bar height seems maxed out.  Tried going up another chain link but it’s too tight to lift it into place.
And yes the jack is up a couple inches above the wood blocks in the pic, looks like it may be touching lol!
The rear sag isn’t too bad.  From fender to tire is 5 1/2” up front and 4” at the back.  Unloaded I’m about 6” front and back, with levelling kit.
At the end of the day if you want to tow with a levelling kit, plan to install air bags I suppose.
Trucks come out of the factory with a natural rake to compensate for loading.
Edited by madconcept
47 minutes ago, madconcept said:
No my chains are maxed out.  Tried going up another link but it’s too tight.
And yes the jack is up a couple inches above the wood blocks in the pic.
The rear sag isn’t too bad.  From fender to tire is 5 1/2” up front and 4” at the back.  Unloaded I’m 6” front and back, with levelling kit.
At the end of the day if you want to tow with a levelling kit, plan to install air bags.
Trucks come factory with a natural rake to compensate for loading.
Right on. I’ve had a few friends who were “told” how to setup their WDH but didn’t know there was some adjustment to dial it in perfect.
Yea, know what you mean on both, it had rained the last 6 weekends in the Seattle area before this one.
Try to tilt the WDH head down you should be able to loosen the bolts, add a shim or washer between the head and shank to gain some additional leverage on the WDH spring bars you should be able to get more weight transfer to the front wheels.
Edited by Greyhound6.2
Thanks.  I just adjusted the tilt by adding another washer.  Don’t think there’s enough room left on the shank to add anymore so I think that’s all I can do.
Hopefully my truck doesn’t drive all squirrelly!
Big/only reason I was able to get this truck because I promised my wife it would handle our TT better than my old truck lol!
I’m hoping I don’t have to go out and get airbags now!
Love how the truck looks unloaded with the level kit though!
What's interesting about your picture is that your shank seems to be angled up.  Is there a lot of play in your shank when in the receiver?  I had that problem on my 2008 Tundra.  The whole WDH would tilt up because of the loose fit in the receiver.  Then I had to add a lot of washers (head angle) to get the WDH set up properly.  I added a thin shim to the shank to make it tighter in the receiver.  Then I honked down so hard on the WD bars that I bent the receiver on the Tundra.  Oops.
Mine does that what kind of shim did you use?
Not the greatest pic but borrowed my brothers car hauler to move furniture to my new house. Don’t do much towing (none) but she did it like a champ even when loaded right up.
Pretty happy with the sag even with the off road suspension. Didn’t even have the equalizer bars installed since I was pulling through the inner city.
Edited by killramos
Picked up a new trailer and heading out tomorrow. I have adjusted the saddles for the WD hitch up two holes. Bars have lots of tension but assume it’s the leveling kit on the truck preventing me from getting it level with the trailer. Not the end of the world....
Edited by nick242
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,375 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
