10 hours ago, Greyhound6.2 said:
Mine does that what kind of shim did you use?
I cut up a cookie tin for shims.  Not the most elegant solution but it worked.
8 hours ago, nick242 said:
Picked up a new trailer and heading out tomorrow. I have adjusted the saddles for the WD hitch up two holes. Bars have lots of tension but assume it’s the leveling kit on the truck preventing me from getting it level with the trailer. Not the end of the world....
Thats a big trailer! Whats the tongue weight on that beast?
Tongue weight is 730 lbs. We are leaving in a couple of hours and I just might raise the saddles one more bolt.
Thats impressive. Whats the trailer weigh?
Unloaded it’s 6400 lbs. Trailer is 36 ft in length so it’s not overly heavy for its size.
Not at all for the size! Looks like a nice rig! Hows it tow?
It towed very well. Trip was around 2 hours so nothing major. Truck and trailer are a good combo. I did a muffler delete back in March and haven’t really towed yet...boy it was loud with a load
Why i didn't go crazy with exhaust. That drone is killer lol
22 hours ago, 6.2TB said:
Had to make it a matching set!
Nice pro xp i have allot of fun with mine
Edited by Greyhound6.2
Very cool!   Thanks for posting your pic, I have been trying to decide between red or black bumpers, your pic made up my mind for black.   I have the same roof as you...and that’s a lot of red!
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
