Mine has started doing it more, meh it's just cheap plastics, gotta be the rear spoiler. Has anyone tried moving their side mirror caps around? I swear these things are barely popped on to the mirrors. I saw one of mine was sticking out a little so I pushed it back in.
My 19 Trail boss does not at 5k miles. The 19 lt double cab loaner I have did it three times on highway today. Sounded like an acorn dropping from 30 feet up and hitting the roof towards the rear brake light area.
Perhaps the bolts that hold the third brake spoiler to the truck are torqued too tight?
On 9/5/2019 at 4:08 PM, jkspinks said:
Has anyone had the dealer see if they can fix this issue?  My AT4 is at the dealer right now for the pop.
Let me know if they are able to fix it. If so, it would be awesome if they let you know what they did to resolve it. It seems nobody has an answer yet. Thanks!
I was reading these posts as they would come to the top, thinking "wow, this stinks!" On the way home from church today, 19k miles on the truck, I heard the pop. quite a few times too. It seemed as if when going 35ish miles an hour and let off the gas, that I would hear it. Dang it!
On 9/9/2019 at 5:31 PM, ShamrockShooter said:
Have someone sit in backseat and try to identify where noise is coming from
It's definitely coming from the roof/spoiler. Others have recreated the noise. Question is what exactly is the cause and how to get Chevy to figure out a solution.
Dealer had mine last week, and thought they had identified the issue causing the pop.  They had me come in Friday after work and drive around for a bit to make sure what I was hearing was the same as what they are hearing.  It was.  Took it back Monday morning because I needed it over the weekend.  They called today to tell me they found the issue.  It is the spoiler causing the pop.  The service advisor said that the spoiler is two parts that are plastic welded together (his term).  At two spots, on mine the welds have broken  He says because of this technique to put the two parts together, they can't fix it because they don't have the equipment to do it.  They were going to try epoxy, but decided against it.  They checked the system to get a new spoiler, which will have to be painted.  When they checked, it showed none available nationally.  Then they do something else for a special order request.  Right now they are waiting to see how long it will take to get the part to replace it.  He said they should have a better idea tomorrow.
Good to get confirmation on what it is, I was 99% sure it had to be the spoiler after pushing on it a little and hearing the creaking it made. The sad thing is that even after you get your new one, it will probably happen again.
We have had one come in with this issue so far. Had to add some dumdum between the roof and spoiler bolts. Customer is very, very particular about his truck and have not heard back from him on the sound in over a month.
Just got my CC RST no sunroof this past Monday, as of today it has 170 miles. Noticed the sound yesterday but didnt think about it too much thinking that something had dropped on the roof. Did it again about a handful of times today on the freeway with open sky, twice in 5 minutes. Glad to know that the sky isnt falling ?
Edited by 808 HI
i have the same noise on a 1 month old 2020 ccsb 2500 HD, no sunroof. it makes the noise every morning on the same turn on my way to work. from inside, it kinda sounds like it is coming from the passenger side rear corner of the roof. the first time i heard it i thought something hit the roof also. i heard it from the outside of the vehicle while i was washing it too. it is coming from the rear roof spolier/high mount brake lamp area. i was washing the roof when i heard it so at least i was up kinda close to it. curious as to what it is but cant imagine it is too much to worry about.
11000 miles on my 19 with sunroof. No noise at all.
I have found the thread that explains the problem I was wanting to describe. I will wait now to see if GM can really come up with a real fix. Good to know now its coming from the plastic spoiler. No sunroof here
    LCH14
    LCH14
  • Who's Online   1 Member, 0 Anonymous, 1,235 Guests (See full list)
    • Yea a fluid change is in order here. Honestly, your transmission didn’t even get hot. During the summer in stop and go traffic I’ve seen my 8l80 get up to 216 and it was still shifting smoothly.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
