Anyone getting a popping noise from their roof?  Every morning when I pull out of my garage and go over a slightly angled transition between my driveway and the street I get a popping from the roof.  I've heard it several other times when driving at low speed as well.  It sounds like the sheet metal is flexing, like if you were to slightly indent a piece of sheet metal, it slightly indents and then you push it in another spot and it pops out of that indent.  I have gotten a very similar noise from the lid on my washing machine.  I do not have a sunroof.
I have a similar sound, but mine sounds like a loose clip shifting when I come to a sudden stop, turn sharp etc.
I've learned long ago to not let interior noises/rattles irritate me.  If you let them, the dealer will end up tearing apart the interior, and I gaurantee it'll never be the same. Noise may be gone but you're left with ill fitting panels, and scratches everywhere.
Ya, I try not to go into the dealer at all unless necessary.
my 2016 used to do that.. when I would take out of garage and the hot sun started beating down
10 hours ago, THE SILVERADO said:
Mine did this the first couple weeks, but seemed to have gone away recently.
Hoping my goes away too then, I only have about 700 miles on it so far.
I have only heard the popping sound while washing my truck not while driving. When I spray water on the roof I do sometimes hear a loud "popping" noise.
Maybe the same noise, but different causes.  Cold water on hot metal might be having the same effect as my driving over un-level surfaces at low speeds first thing in the morning.  As long as it doesn't get worse I'm not going to worry about it.  I know the dealer would just give me "could not recreate" or "normal operating characteristics" of the vehicle.
Mine does it but its getting less and less and not as loud anymore . I had the truck out all day today and it didn't do it so I guess its about gone. Hell when I first heard it I thought a bird dropped a bomb on my roof.
Edited by Silverado4x4
I drive about 100 miles a day.  I get one clear pop on the way to my shop, and one on the way home.  Freeway, straight driving, normal consistent speeds.  Sounds like something dropping from a tree on the left rear side of the roof.  No trees in sight.
Anyone had had this addressed yet?
  • 3 weeks later...
Bumping this to the top.  Anyone else getting this once and a while pop from the roof?  Mine is starting to do it more than once per drive now.  Hell, even my 7 year old daughter said “what just tapped the roof”?
Dam, I am glad I am not the only one. Mine never had made any noise and then it randomly started one day and it drives me nuts. It sounds like something landing on the roof. I know for a fact that it is coming from the rear but I can't pinpoint. I thinking it could be coming from that rear spoiler these new trucks have but you have to pull down the entire headliner just to get to the damn thing. I really want to sound deaden the roof but I absolutely hate pulling down the headliner and wanted to avoid it for as long as I could. Just really curious as to what it could be.
Edited by Ericruiz911
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
