Wasn't happy with the TrailBoss exhaust note, had local shop put a flowmaster muffler in instead.  Much smaller than the BBQ grille sized OEM muffler.  Not much louder though.  Exhaust shop guy says the new chevy's are really quiet due to the cat and a resonator.  Solution was to delete the muffler all together.  Much better.  No drone at speed, but a good amount of rumble when accelerating.
If I hadn't put the flowmaster on initially, shop would've charged $50 to remove the factory muffler.
Just fyi, seems like a good alternative to buying the OEM performance exhaust.
You will find if you experiment with covering the resonator mesh screens it will dramatically change the sound.  My magnaflow was very quiet too. I currently have the middle resonator mesh on each side only uncovered and I think it’s the best sound so far.
Muffler tape works great. Cut it to the shape and stick it on. So far it has stuck great and it doesn’t look like a hack job.
Here's a vid, audio kept cutting out of the iPhone recording for some reason... probably too loud for the microphones,  but managed to capture a bit of it.
IMG_0195 (2).m4v
That does sound good. Much like a complete aftermarket system.
I am really a fan of the new T1 dual rectangular exhaust look through the bumper.
RAM and Ford are still using round tips.
Sounds good on the start up but I would think its going to make a popping and cracking sound when letting off the throttle going down the road which is going to sound like crap.
I have an electric cutout on mine that opens before the muffler via remote control.  The sound is very deep and loud with no drone.  There is a back crackle when slowing down only if you are in 1st gear between about 16-22 mph but I love how it sounds lol.
I've been hesitant to go this route because I've heard you lose bottom end HP and torque
Yup. Same goes for open exhaust, headers etc which only benefits at high RPM like drag cars that spend there time at max RPM where they benefit but for a everyday driver you will loose hp and torque.
There's no noticeable loss of power, If anything deleting the muffler would result in a modest (+5) HP gain.   There is some back crackle at low speed deceleration though.  Wife doesn't like it, but sounds good to me!  Thinking about covering the resonator vents next to see what happens...
That sounds awesome! So now that you drove it more, how’s the highway noise/drone if any? I do lots of highway driving and this is my biggest concern. I want to get rid of the flapper because the noise it makes at low speeds/idle annoys the hell out of me. Thanks for the video and your input
I've honestly noticed 0 loss in power. Its accelerates just as good when its closed as when it's open but open sounds way better.  I have some YouTube videos posted in a different post if you want I can post them here.
Surprisingly quiet at speed.  I've had drone with cat-backs on previous trucks and know what you mean, but no drone here.  Gets loud on mild to hard acceleration only, slow or regular driving is tame.  I'm not sure what the flapper is, but there is some back-crackle during low speed deceleration if that's one in the same.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 686 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
