Having a hell of a time finding the gear ratio on this '18 sierra 4x4 SLT.  Apparently GM stopped putting RPO stickers in the vehicle, and replaced with a QR scannable barcode...I guess because the $.19 cost of the stickers couldn't be offset by a $55k+ MSRP on the truck?  So I scanned the QR code and got back an what looks like an incomplete list, don't see anything about the gear ratio (GT4, GU4, GU5, GU6, G80) because the list gets cut off with a bunch of ,,,,,.  Downloaded 5 different QR apps approved by GM for the new RPO sticker, same result.
,2018,TK15543,09,17,06,VNHB58, AXK AY0 B3F CJ2 C5Z DL3 EF7 E63 FHO GAN H2U IO6 I18 JD9 L83 MAH MSL MYC NP5 NTB RC4 RC7 RD5 RUF UDD UQA U2K V8D WMJ Z71 Z88 4AA 4SA 6F1 7F1 8X2 9X2,636R,,,,
Someone posted a link in here that took me to a GM site with all sorts of build docs on the 2018s, found a table.  Based on my model (TK15543) and 5.3L (L83) engine, I have the following.  I'm the second column w/ 3.08, 3.42, and 3.73 listed out.  So I'm basically right where I started.
I don't have the original sticker, so not sure how to go about getting this info other than getting a build sheet from the dealer (which I will do on Friday if needed). My truck is a texas edition, w/ trailer brake and tow button on gearshift.  Never towed anything heavy enough to care, but looking to buy a ski boat and want to have the facts.  Anyone know how to figure this out other than dealing with the dealership?
Thanks
Edited by Stitch
You can try compnine, but I'm not sure the info you get will be much more complete.  Dealer or a call to GM customer service may be the best route.
Your list is not cut off. The last one is 636R, which is the paint code.
They just don't provide the gear ratio code in the list anymore. See here -> https://gm-techlink.com/?p=9801
You would need to get the full build sheet from your dealer. Or possibly from someone at GM, but good luck getting someone on the phone. There was a GM customer care account on this forum a couple years ago. They actually e-mailed my build sheet to me, but i don't think they have been active in quite a while.
I'd just call your dealer.
7 hours ago, mjm-1957 said:
give me the last 8 of the vin  and i will run it for you
Really appreciate that, thanks for helping me out.
JG164174
Which transmission do you have and do you have Max Tow.  We can tell you from that.
I have had the same problem few months ago.  I went to the service centre of my dealer and one of the mechanics used his account at GM Global Connect (https://www.autopartners.net/) to pull the data and print it out for me.
I have heard that GMC and Chevrolet Chat centre can send that to your email address using your car’s VIN
11 hours ago, Sierra Dan said:
Technology will be the death of us yet!  :smash:    LOL
They eliminated RPO codes in the glovebox so in a few years they can charge shops access to the “scannable” code.
Data aint free.
On 6/7/2019 at 9:27 AM, juscuzram said:
Email your VIN to [email protected]. They'll send you a build sheet.
Unfortunately they have stopped doing this. Should still be able to get a copy from most local stealerships (assuming they are customer friendly) talk to the parts counter people about printing one off.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
