Does anyone have a link to a trans pan with a drain plug that is not so expensive. The stock one is cheap enough do they make a version with a plug ?
2014 GMC Sierrra 5.3L / 6- speed. Not a welder so the weld in plug not really a solution for me.
Thanks,
Yotaman
You can also buy a mamba bulk head fitting it has 2 metal and oil seals on it. Drill hole and install in would use lock tight and crank it down. Then buy a cap. Very cheap and very good. No need to paint or worry about rust.
If you exhaust isn't stock or at least doesn't have the cross pipe in the way of pan the moroso pan for the Camaro fits and looks better. Normal like $300 but Amazon had it for $97.de172e56765162418ef5c73d84015606.jpg
18 hours ago, imiller1974 said:
I never found one, so I made my own. Welded a 3/8" bung and use a plug.
Did the same thing for my 8 speed
Like this then just a -10an cap. Say all under $20 super clean and easy install. I would go in the corner of the pan. Drill and bolt together. Done.90681bc834d87d3b8976a39f381463bc.jpg
I don't have a link but I found a perfect one at of all places NAPA sold one with a drain plug.   This was for a 2008 but I would try there, I seem to remember it was about $40-$60 and I never had an issue with it, perfect fit.
How far does this thing protrude up into the pan?  It looks like it may leave a quart? in the bottom of the pan.  Not that it matters a huge deal, just curious.
On a stock oil pan thickness it screws down flush. But you can always mount it to the side as well.
Yes truck is all stock. Thanks for all the replies and ideas.
Yotaman
The transmission pan is $13.97 on Amazon, you could buy a weld on bung and get it done while your truck is still together. Throw a local shop cash and have them do it while they're working on other projects.
Just looked weld in steel bongs are super cheap. And any muffler shop can weld it in and that would be flush to the inside of pan. Also pans are cheap. I would sell mine but again they are cheap and if I remove trans I will not do so with my aluminum moroso pan on there.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
