On 3/2/2020 at 5:15 PM, Ksalway said:
Wheels: Fuel Rebel 20x9 +1 offset
Tires: Yokohama Geolandar X-AT 295/65/20
Love this look. Can’t tell if it has a lift or just the leveling kit?
2 hours ago, Bluerado23 said:
35/12.50?
I love that method wheel
Thanks me too. They are even better in person it’s hard to photograph the color as it changes depending on light.
Wheels:17x8.5
Tires: 35x12.5
On 7/15/2019 at 5:50 PM, Mastiff said:
- Fuel Coupler 20x10 -18 offset
- Nitto Trail Grapplers 35x12.5R20
- BDS 6 in lift
no rubbing at all
Know it's the wrong thread, but what side steps do you have there? Looks like they huge the frame well
On 10/3/2019 at 9:42 AM, CMillSilverado said:
19' High Country with 34" tires and all stock.
Do you have tire size? Looking to do something similar on 2020 custom 4x4. I appear to have enough space to go from stock 275/60/20 (33") up to 275/65/20 (34") on stock rim and avoiding a lift or level.
Yes they're 275/65/20's
On 3/8/2020 at 5:57 PM, woodsrider11 said:
Stocker Chevy LT 18's with Toyo AT's 275/75r18
Any rub at all? No lift?
It’s the 3.5” rough country lift
On 9/23/2019 at 4:59 PM, Gamecock12 said:
Kept the 22" OEM wheels on my High Country and went with the Fabtech 4" lift with 285/55R22 Nitto Ridge Grapplers. Used 1-1/4 Spacers and still had to trim a bit, but not too much at all..
I realize that this is a pretty old post but I'd love to see more pictures of this set up.  I'm considering a similar set up but concerned that a 3.5 RC lift would leave too much of a gap in the front wheel well. However from what I've read on here,  a 3.5 lift or TB + 1" level might be necessary to prevent trimming.
Sure. I can send some more pics. Anything in particular you would like to see?
Curious, did you have to trim before putting on wheel spacers. I have 285-50-22 's which are only 1-1/6 less in diameter and are nowhere near rubbing on stock wheels.
Gamecock, I would love to see the truck from the side profile with the front wheels straightened? I'm really wondering just how much space if left in the wheel well and how much of a lift is needed to clear the 285 55r22s.  Yours looks great by the way.
No.. The trimming needed to be done due to the spacers.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
