On 6/10/2022 at 11:33 AM, pepe48134 said:
Sorry for the delay,
Hard to tell if the ride is much different from the Tires or the Shocks.
No Noticeable difference in MPG. I think the tire weight of the Non-LT tires help (11lbs per tire lighter then the LT's, unsprung mass is bad for MPG).
Nitto is the only MGF the has a Non-LT tires in this size and the make both the standard and the LT in the same size so you have to be very specific on what you order. I got them from Discount Tire.
Thanks for the advice on the tires. I’ve seen the non LT but as you said, not in this size.  How do you like the Bilsteins?
Cooper rugged treks come in non LT, eibach pro truck struts are an option comparable to bilsteins, very happy with mine, 2” in the front, 1” in the rear.
I wasn’t aware. What size Cooper Rugged Trek are you running? How’s your ride with the Eibach struts? I mainly on pavement but definitely some off-road. Mainly mud.
275/60/20. The eibach kit has lift springs instead of just adding more preload to stock springs. The ride with the eibach kit is much better in my opinion, no more “porpoising” after big bumps or pot holes, you do notice smaller bumps more at lower speeds though.
Lots of non LT in the stock size 275/60/20 (33" tall) its the 275/65/20 (34" tall) that no one makes in a non LT.
Im happy with the ride of the bilsteins, better than stock for sure. I looked into both the eibach and bilsteins. they actually list the same way. They both have adjustable lower spring perch positions to set the ride height. The Eibach's do come with new springs but both the stock and the eibach springs are liner rate springs so to me it was hard to justify the extra costs.
For the rear blocks I called a local suspension shop and they gave me a set of blocks from the previous gen truck, they had a pile of them laying around going to scrap. They are 1.2" cast iron. 5 mins in the sandblaster and some black paint and they looked liked new. OE Ubolts from 2018 truck fit perfect.
There seem to be very few choices in non LT bigger than 275 60 20. Nitto makes a 305 55 20 ridge grappler in non LT that weighs 4 more pounds than your 275 65 20 so I’m pondering the choices. Post some pics after you install your rear block, please. I have less than 1 inch of rake so if I raise the front 2 inches I’ll need to raise the rear also.
I looked at the 305/55R20 but they are the same height as stock @ 33". IMO the height is needed in these trucks more then the width. I also have the 2.7L so un-sprung weight was important to me to maintain fuel economy.
I will post the pics with the rear blocks installed when I get a chance. I Ive been sidelined with a shoulder injury so it might be a little while.
Edited by pepe48134
The weight of your tires is what got my attention to start with. I’m concerned about mpg but also I messed up the ride of my last truck with heavy ko2 tires and determined to not do that again.
On 1/19/2022 at 11:51 AM, GA_RST said:
What’s up everyone, been a while since I’ve posted but I sold my 2020 LTZ and recently purchased a 2022 RST Z71 limited (I do not like the refresh personally). I put a leveling kit and 285/65/20 Nitto Ridge grapplers on the OEM 20’s. Minor rub so I removed the bracket and did some very minor trimming of mud flap and zip tied liner. No rubbing at all now.  Really impressed with these Ridge Grapplers. Ride like the stock tires.  Now I know why they’re so popular.
That's a good looking setup. Exactly what I'm looking to do. What leveling kit did you use and did it perfectly level your truck? Did you have to use any wheel spacers to clear the tires? Any other pics would be great!
Recently picked up my new ‘22 AT4 and swapped out the Duratrac’s for 295/70R18 Ridge Grapplers. Kept the stock setup and surprisingly have no rubbing even at full lock.
Edited by Hickory
All stock 22 refresh rst 6.2 liter, s&b cai, Gibson cat back exhaust, 15% ceramic wrap, 50% ceramic on windshield and sunroof,  275/60r20. Measures 1.5 inches of rake. Might go to 285/60r20 but that's it. No leveling kit needed. I tow a boat and trailer and the tongue weight levels truck out pretty good
Edited by Bhains187
I'm also thinking about running a 285/60-20 when my wheels get here.
I just have a stock AT4 at the moment, but will most likely level it at some point.
Hoping the 285/60's won't rub too much
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 764 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
