On 2/24/2023 at 1:49 PM, Asmith721 said:
I didn’t change gears or anything so didn’t change any setting for that portion
What is yours set at then?
3.23
Swapped out the trailrunner at for some ko2. Not gonna lie, once I got the ko2 was in the fence because the wranglers were a very good performing tire with a great look for a street truck. But 50 miles later, can see why all the love.
275/60r20 fuel vapor  20x9 +2mm
Edited by Russ757
Went with Rough Country 2" level for now with 35x11.50r20 Ridge Grapplers on stocks no spacers. Going to be towing and not a fan of spacers for towing. Did the mud flap bracket delete and no rubbing now.
Edited by Cadviking
Factory wheels and most aftermarket wheels are NOT designed to use ET lugs. You do NOT need ET lugs, just standard conical seat lugs are fine.
I had a set of General Grabber ATX's installed today. I went with stock tire size for this truck, LT275/60r20. I have to say I am very pleased so far. These actually make the truck ride a lot nicer than the OEM equipped P-rated Bridgestone Alenza mall terrains. They are very smooth, and surprisingly quiet! Would absolutely recommend these tires. Sorry for the less than great pics, but it was raining, so I was in a hurry.
IMG_5604.thumb.JPG.261a01ee2f20d7f74008813b1a759403.JPGIMG_5605.thumb.JPG.52445041b358f059fd3459d9a622e4cc.JPG
Edited by fondupot
Tons of great setups in here but I'm struggling to find lots of photos of Denalis with updated wheel/tires! Really hard to visualize what would look better than the stock setup.
I agree as I do not like my Denali Ultimate OEM wheels, I'm trying to find something else.
Yeah me either....I did see a post deep in this thread of someone who chromed their Denali Ultimate OEM, looked pretty good...but I am pretty sure I'm wanting something black with a bit more aggressive tire than the Alenza.
I have noticed Dave Sinclair's auto doing a lot of "custom" Denali...not sure the word custom is appropriate, but some of these give a good idea. However, I don't want to do a bunch of chrome delete.
Not a bad look at all...I'm not going to lift mine, just level, but still think black rims and more aggressive tires would look great.
I agree about the Alenza's, I had them on my 2019 High Country and I swapped them out for a little bit wider Nitto Terra Grapplers. I'm pretty sure I'm going to go with the 2019-2021 High Country 10 Spoke wheel in Chrome, they look nice in my opinion and really easy to take care of. While I do not like the Alenza's I'll probably run them until they need replacing because after coming from my HC with Borla Touring Exhaust, CAI and "E" tires I'm really enjoying the quiet now, I've got my Corvette and Wrangler if I need noise.
I have been looking for tires for the stock 22" rims. I was hoping for 285/55/22 but the choices are limited. Has anyone been able to find an All terrain that isn't as aggressive as the recon grapplers? On my last truck I had some michelin all terrains that where great but they are not offered in a 22". Anyone have any insight? I have been watching the forums and checking vendors for almost 2 years now.
I ran Nitto Terra Grapplers on my 2019 High Country with OEM 22", fit no problem.
That's actually a great idea re: the 2091-21 high country wheels. Those are good looking wheels and I think the chrome will look pretty sick to be honest. And agree on Alenzas, mine are only 22k miles in so no rush to get rid of perfectly good tires!!
im looking at getting rid of the 20s and doing some 18s what size are you guys doing with a level kit
was looking at 18x9 295/70/18 would that be a good fit?
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 890 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
